how are you recording this video?hey guys.
I noticed a few of my video captures with a ghosting affect. Any insite how to remove it.
<iframe width="560" height="315" src="video - YouTube" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
do as stated above.okay,
its a hikvision DS-2CD2145FWD-I. would a screen shot of my setting page help? several Cameras in my setup exhibit this.
Yes. Follow directions above. Also lower the bitrate by half, its insanely high.Heres is the setting page of the hik that recorded the video.
So I played around with iframes and didn't see any improvement. This all started after having to update my intel drivers. Ive tried both recommended drivers for 8th gen cpu's. No improvement with either drivers. Ive never had to mess with iframe rates to prevent ghosting in the past. I cant seem to find the previous drivers I was using. I do recall reading a thread on inserting specific files in the drivers folder to prevent memory leak. I cant seem to find that thread. Heres another video of the issue. System specs are z370n wifi with 8gb ram and i3-8350k. No overclock.
DNR is set to 50 out of the box, so if it's anything but, you or someone changed it. Try to out and see what happens.Ill have to check. Ive never changed them. It just seemed odd that now I have to tweak those settings.
Okay, did you change the I Frame to 15?I did have it at that prior to the Screen grab. I reset the camera and it went back to that. Its at 50.
