Hi guys, I did a quick search but maybe I am not using the correct technical term for this, but I have noticed that usually on the hikvision cameras that I have owned, I get a broken image during motion events. For instance if I walk by the camera the image of the subject moving gets all messed up. This camera is:
DS-2CD2542FWD-IS
Things get better if I am bump the resolution down from 2MP to 640x360, but I still happens. This doesn't happen with Dahua cameras - albeit the Dahuas I have are newer?
I have tried so set a CBT, it helps some but not enough.
I have a hikvision 5PM camera which is newer IP3.0 series and does not glitch at all. Could it just be that some of the "lower end" cameras can't encode / decode fast enough even though they are advertised to run 1080P @ 15 FPS (for example)
Last but not least, looking at the recording they seem to be fine, but I just want to make sure that they dont get messed up the day I really need them to work well.
DS-2CD2542FWD-IS
