I just upgraded from v3.66 to version 4 a few days ago (same settings) and have been getting a ton more false positive motion alerts. I fiddled around with the motion settings but still couldn't get it to be as precise as v3. I see in v3 there's only a checkbox for object tracking, but in v4 you can now specify distance traveled and object size, etc. Is there a setting I can put in for object detection that'd give me the same behavior as v3?
Also, I was playing around with "Run video through motion detector" to try to troubleshoot further, but I cannot figure out how to use that functionality. It seems no different than just regular playback with the exception of the zone overlays. How do you use that feature? Does it tell you when things are triggered? Also, what are the different rectangle colors mean?
I might think about downgrading it back to v3 if I cannot figure this out.
Sorry for all the questions but I'm just a bit frustrated to expect version 4 to work the same as version 3 given the same motion settings.
