Get Older BI Versions
rfj
Pulling my weight
Oct 26, 2014
415
123
Where can I get an older version of BI, specifically 5.3.3.8. I uninstalled BI and want to reinstall it. In this forum I found Blue Iris Updates (64 bit) - History but it turns out those are just updates and not full installations.
I haven't done it but @fenderman says here that this below will work:
  • Go download and run the full installer of V5 from Blue Iris ==>> here.
  • Then run the desired update (5.3.3.8) and it will revert back
Do you have your BI license info handy?
Any time you decide to uninstall/re-install BI it's good to go BEFORE YOU UNINSTALL to BI "Settings" => "About" and click on "Email support" button at bottom-right to copy to clipboard, then paste text into Notepad, Wordpad, etc. and save the file as text; then you can copy/paste into the new install of BI when it asks for your license key.
Yep, this works fine. I just did this last week.
