Hello all!
I just joined this forum so that I could ask a couple questions. I've lurked here the past week reading the wiki, sticky, and icky posts all around about general camera knowledge and hardware reccomendations.
I am able to configure managed switches, vlans and vpn's and run cables both copper and fiber.
I will start by saying I will install this system at my parents house. My dad is higher than average tech savvy and can usually figure out stuff if it breaks so I figured blue iris is a great choice nonetheless, this is also because he wants to check it out as a system for another location where more than 40-50 cameras will be installed in a not too distant future (6 months circa) My questions about BI are:
Looking forward to hearing advice from you all, thank you!
- With the proper beefy hardware is BI still reccomended for a 50 ish camera system? I was thinking of buying a good refurbished server to run those on. Would that be a waste of resources compared to other more commercial offerings or is it still in the realm of possibilities? Hoping for imput from people that have such a system either at home or in a commercial setting.
- For a home setting with a fully enclosed metal fence (averages 1.7 meters do to local regulations) do you reccomend placing cameras facing from the house outwards or from the fence outwards? Also how much overlap do you usually plan for?
- Dahua or hikvision? I know dahua is very well regarded here in this forum, but I have some difficulty sourcing them in italy due to long wait times or b2b distribution. I've only been able to find a couple online stores with severely marked up prices. I was lookin at this for now in order to test out the angles and positions before buying fixed lense models: IPC-HDW5231R-ZE (which I can find on IPVM but not dahua's own website curiously enough) but am open to other suggestions in the sub 180 max 200ish Euro category. I am having a hard time distinguishing between the HDW22XX series and HDW52XX series, from what I gathered the CMOS is the same? Maybe the 5x has better IR illuminators? All the advanced features I need are Perimeter and motion trigger events with very optional sd card recording of those events.
- On the other hand I noticed hikvision have more lens size choice, I do not know how relevant that is but It might matter? Also is it true hik cameras have slightly better dark performance? What would the equivalent cam to the 22xx series and 52xx series be?
