gate sensors.
hmjgriffon
3,369
976
North Florida
I'd like to rig up sensors on the side gates that go to the back yard so I know if they are opened, any ideas for something out door I could do this with?
Reactions: hmjgriffon
Ive been meaning to get something like this for integration with my SmartThings system. That looks like a good option hooked up to a zwave open close sensor with dry contacts.
Sent from my Pixel XL using Tapatalk
So would you just hook the two wires into the dry contacts of the zwave door sensor? Does this thing need power run to it?
mine are wired up to my cameras watching the gates
these dont require power or anything; its either an open or closed circuit.
Uh, two wires. lol
Yes, but I didn't know if it matters which went where until I saw how it works on the inside, for instance I've got a PIR sensor to play with that has two terminals that say NC and it was confusing, all I can say is I'm a noob to this type of stuff.
Better to ask and be safe. In this case, it would be hard to break something, but you never know.
It sucks to connect something wrong and let out the "magic smoke".
Exactly man, when we're talking about hooking stuff to $170-$500 each cameras I don't really want to risk frying one
A PIR typically has a relay inside and often a set of both NC (normally closed) and NO (nomrally open) terminals
Just pulling your chain. You IT guys can do stuff I can't imagine. I do get the switch thing though!
