Hi,
I'm thinking of installing a camera in the garage. The garage has a wired connection from the router in the garage to the router in the house. Could I connect the ip camera to the garage router and will it then be found on the network via the nvr, the nvr is in the house connected to the router in the house (as long as I ensure the garage camera has separate power). If not, what would be the correct way to install it.
Thanks
Thanks
