- Nov 12, 2017
- 100
- 8
I recently noticed my app (ios and android) were having a hard time connecting, displaying clips, displaying live, etc. I checked my PC and noticed gaps in my recordings. Average 3-5 minutes and on and off for hours, some gaps were hours long. The multiple gaps were causing BI to write new files, and my 240GB SSD would run out of room within a day or two. Instead of 1 clip per cam on each day, I was getting hundreds per cam
This started happening around the same time I upgraded to BI5.
Downgraded to BI4, cleared out my clips that dated back to around the BI5 install, and all. seemed good.
Today (2 or 3 days later) it's happening again, with BI4. Cleared out the SSD and already got a gap within 5 minutes of rebuilding the DB.
Tried to look at logs, and it says file cannot be found.
9 POE cams
i7-7700
16gb ram
240gb ssd
8tb hdd
System has been running flawlessly for about a year now until this happened.
Sent from my SM-N960U using Tapatalk
9 POE cams
i7-7700
16gb ram
240gb ssd
8tb hdd
