- Feb 8, 2015
- 90
- 1
I did the 'test' and that worked, but nothing seems to get uploaded to the offsite ftp server. am I missing an option somewhere? can someone walk me through how to get it going!?!?!?!?
There is a bug in 2.1 that may be causing your issue...you can leave it as is...that option depends on what you want to do once the file is uploaded...you still want a local copy so you can easily review footage...hmmmmm. do I do the 'leave file as is' for after upload? seems like none of the files are showing up in the clip browser now haha. but they are getting sent over FTP.....
not sure...one user reported loosing clips..you can roll it back using the update file i posted here http://www.ipcamtalk.com/troubleshooting/2926-error-0-a.html?highlight=reportthis bug is just making them not visible or what? I can't lose any footage locally....
2.2 has been released so you may want to try that. What do you mean by glitchy?alright I'm on 1.14 and the video is still glitchy as crap. I'm doing the direct to disk option, and the live feeds look great. it's just the clip playback.... ideas?
its requires permissions...
yes, that is the ghosting i was talking about...try the suggestions above..
