Ok, So I need separate wire for a speaker and it cannot be transmitted over current CAT5?I think you have to splice/hook up your own Speaker for the audio-out, then use either web interface with a pc mic or the phone app to talk to it.
The speaker will come out from the camera's audio out port. the data will transmit over the current cat5
POE switch->cat5-->camera
camera-->speaker
It will record with the built-in microphone though. You only need a speaker for two-way audio.
Not a bad idea if you want two-way. One-day I will do that, at the moment I've just got sound, it's quite good.
DS-2CD2542FWD-IS, maybe 5 to 10m, it's a mini microphone so I think that's quite good!
Phone App, NVR software, download file. All works.
