I would make adjustments and then see how it is. You might need a little WDR/SSA, but I would only use it if you can't dial it out with the other settings.
It also may not be a bad idea to physically turn the camera 90* and then go into the camera's UI and adjust the rotation to correct it. This would give you more top/bottom and less of the wall. It's worth a shot and doesn't cost you anything.
For reference, this is my wedge next to the door.
