pinoybear n3wb Oct 28, 2018 6 0 USA Sep 8, 2023 #1 My Android 13 phone keeps notifying me that Blue Iris is having frequent crashes. Un/Reinstalling the app doesn't change anything. Anyone else have this problem?
S SpacemanSpiff Known around here Apr 15, 2021 1,710 3,189 USA Sep 8, 2023 #2 Check the BI logs on the server for more detail Consider sharing some of the details here
pinoybear n3wb Oct 28, 2018 6 0 USA Sep 8, 2023 #3 It didn't occur to me the app crashing might have something to do with my Windows server. But the server log is very uneventful.
S SpacemanSpiff Known around here Apr 15, 2021 1,710 3,189 USA Sep 8, 2023 #4 pinoybear said: It didn't occur to me the app crashing might have something to do with my Windows server. But the server log is very uneventful. Click to expand... Much to your point, I am curious if it is the app, or the server itself
pinoybear n3wb Oct 28, 2018 6 0 USA Sep 8, 2023 #5 After my last reply I thought you probably meant the logs from the app itself, but the logs section is a mirror of what you view on the server. I don't see that the app keeps its own logs.
wittaj IPCT Contributor Apr 28, 2019 30,849 59,196 USA Sep 8, 2023 #6 Could it be the app is shutting down in the background and that is considered a crash? I am on 13 and don't get that message.
pinoybear n3wb Oct 28, 2018 6 0 USA Sep 8, 2023 #7 I have it excluded from being put to sleep. I don't know why it would be shutting down otherwise. Are you on a Samsung phone with OneUI?
wittaj IPCT Contributor Apr 28, 2019 30,849 59,196 USA Sep 8, 2023 #8 Yes I am on a Samsung with OneUI
