We have been putting in Uniview NVRs for years with no challenges like this whatsoever, but we recently had to upgrade a client's Alibi Witness system to the Alibi Vigilant to be in compliance. The Vigilant is nothing but a Uniview with their logo slapped on the screen.
The unit is running one HD so there are no groups.
On the system are 8 generic/stealth IP cams from Amazon that are indoor, and 8 Alibi Witness outdoor cams. All are now ONVIF since Alibi Witness doesn't play with Alibi Vigilant.
The indoor/generic/Amazon cams work flawlessly. The outdoor Alibi Witness cams are frame skipping, so when watching the on screen clock you see it tick off every two seconds.
This is not bandwidth related as it does the same thing on the LAN, and if I log directly into the Alibi Witness camera and go to Live View all streams smoothly.
On what is probably an unrelated symptom, no matter what I do with the Alibi cameras, they will not stay in sync w/DST, but the cheap generics are fine. I have turned off time sync at the NVR, turned off sync with time server at the cameras, set them to manual, nothing works other than setting the time zone one zone to the east as a temporary fix. It's probably unrelated, but no harm in mentioning it.
I did update the firmware on the NVR, but no joy. Any of you guys fought this one? Thanks in advance.
