Foxes Chase A Cat Up A Tree
lulu5kamz
1,197
3,978
The fox that climbed the tree decides to give up on the cat and climbs down and walks away. The second fox also gives up but marks it's territory and then walks off. The cat climbs down and runs back to where it came from.
This is cropped and zoomed quite a bit and it's at night, so not quite as good images as yours, but fun nonetheless. And also the full view from the camera, it's a 5442 turret with the 3.6mm fixed lens. The shutter speed is 15 msec, a bit faster than 1/60th, and this camera stays in color mode most of the time. Even with a fairly bright street light, it's still very impressive.
That's a nice camera. I use a 2.8 mm lens as my wide view cam. It also stays in color 24/7. It has a very sensitive mic, did you not capture audio on this clip?
