- Sep 1, 2017
- 29
- 6
I have a Foscam R2 that I have been operating successfully for the past several years running on an old Dell Inspiron desktop with Windows Vista and BI 4. I recently upgraded to a refurbished Optiplex 3020 with Win 10 Pro and BI 5; and I'm wringing out the new configuration. I've noticed some video pixelation / smearing issues with moving figures in the frame. The first image below, taken from a video clip, is relatively clean. The second image, a second later, illustrates the problem. The camera settings are: Stream Type - HD, Resolution - 1080P, Bit Rate - 2M, Frame Rate - 15, Key Frame Interval - 15, Rate Control Mode - VBR. I've tried changing Resolution, Bit Rate, Frame Rate, and Key Frame Rate to no avail. I've noticed that the BI Settings/General screen shows Main FPS: ~14.5 / 0.0 Key. The 0.0 Key value is consistent, regardless of the Key Frame Rate setting. I have also noticed that the Foscam net plug-in application live video stream does not show the pixelation / smearing problem; it's only apparent in BI. I was hoping someone has seen this type of problem, and could point me in the right direction for correcting it.
