I have a model G2 that has some issues. I got it used, and it would not come up. I requested and received the recovery image from Foscam and tried to recover from it. It did not seem to work, so I hooked up to the serial port to see what was happening. It does try to boot but runs into issues with 'No space on device" errors. When I run the recovery image (from SD Card), it does boot in recovery mode, does an erase, and then write of the flash:
_spi_flash_erase: addr 0x380000, len 0xc00000 100%(cost 48416 ms)
SF: 12582912 bytes @ 0x380000 Erased: OK
_spi_flash_write to 0x380000, len 0xc00000 from 0x21000000 100%(cost 22315 ms)
SF: 12582912 bytes @ 0x380000 Written: OK
It loads the Linux kernel and starts to come up but then runs into the no-space issue and goes into a loop trying to start the web GUI. I can break out of this and get to an "IPCamera Login:" prompt, but I can not figure out the login. I tried root / ipc.fos~ but that did not work. I think that if I can log in, I should be able to figure out why there is a space issue.
Does anyone have the login credentials?
Thank you.
Thank you.
