U-Boot 2010.06 (Jan 25 2013 - 10:58:11)
DRAM: 256 MiB
NAND: Special Nand id table Version 1.35
Nand ID: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
No NAND device found!!!
0 MiB
Check spi flash controller v350... Found
Spi(cs1) ID: 0xC2 0x20 0x18 0xC2 0x20 0x18
Spi(cs1): Block:64KB Chip:16MB Name:"MX25L128XX"
In: serial
Out: serial
Err: serial
Hit any key to stop autoboot: 0
16384 KiB hi_sfc at 0:0 is now current device
## Starting application at 0x82000000 ...
Linux version 3.0.8 (root@ubuntu) (gcc version 4.4.1 (Hisilicon_v100(gcc4.4-290+uclibc_0.9.32.1+eabi+linuxpthread)) ) #29 Sun Jul 13 23:18:12 PDT 2014
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
CPU: VIVT data cache, VIVT instruction cache
Machine: hi3518
Memory policy: ECC disabled, Data cache writeback
AXI bus clock 200000000.
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 48768
Kernel command line: mem=192M console=ttyAMA0,115200 mtdparts=hi_sfc:1M(boot),4M(kernel),11M(jffs2)
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 192MB = 192MB total
Memory: 183892k/183892k available, 12716k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xcc800000 - 0xfe000000 ( 792 MB)
lowmem : 0xc0000000 - 0xcc000000 ( 192 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.init : 0xc0008000 - 0xc0627000 (6268 kB)
.text : 0xc0627000 - 0xc0a80000 (4452 kB)
.data : 0xc0a80000 - 0xc0a9c4a0 ( 114 kB)
.bss : 0xc0a9c4c4 - 0xc0aafc4c ( 78 kB)
SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:32 nr_irqs:32 32
sched_clock: 32 bits at 100MHz, resolution 10ns, wraps every 42949ms
Console: colour dummy device 80x30
Calibrating delay loop... 218.72 BogoMIPS (lpj=1093632)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
NET: Registered protocol family 16
Serial: AMBA PL011 UART driver
uart:0: ttyAMA0 at MMIO 0x20080000 (irq = 5) is a PL011 rev2
console [ttyAMA0] enabled
uart:1: ttyAMA1 at MMIO 0x20090000 (irq = 5) is a PL011 rev2
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
cfg80211: Calling CRDA to update world regulatory domain
Switching to clocksource timer1
NET: Registered protocol family 2
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
squashfs: version 4.0 (2009/01/31) Phillip Lougher
Installing knfsd (copyright (C) 1996
[email protected]).
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
fuse init (API version 7.16)
msgmni has been set to 359
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
io scheduler noop registered
io scheduler deadline registered (default)
io scheduler cfq registered
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
brd: module loaded
Spi id table Version 1.22
SPI FLASH start_up_mode is 3 Bytes
Spi(cs1):
Block:64KB
Chip:16MB
spi size: 0x16777216
chip num: 1
3 cmdlinepart partitions found on MTD device hi_sfc
Creating 3 MTD partitions on "hi_sfc":
0x000000000000-0x000000100000 : "boot"
0x000000100000-0x000000500000 : "kernel"
0x000000500000-0x000001000000 : "jffs2"
Fixed MDIO Bus: probed
himii: probed
Invalid HW-MAC Address: 00:00:00:00:00:00
Set Random MAC address: BE:BF:08
0:9A:CF
PPP generic driver version 2.4.2
SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256).
CSLIP: code copyright 1989 Regents of the University of California.
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <
[email protected]>
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
hiusb-ehci hiusb-ehci.0: HIUSB EHCI
hiusb-ehci hiusb-ehci.0: new USB bus registered, assigned bus number 1
hiusb-ehci hiusb-ehci.0: irq 15, io mem 0x100b0000
hiusb-ehci hiusb-ehci.0: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
hiusb-ohci hiusb-ohci.0: HIUSB OHCI
hiusb-ohci hiusb-ohci.0: new USB bus registered, assigned bus number 2
hiusb-ohci hiusb-ohci.0: irq 16, io mem 0x100a0000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
TCP cubic registered
NET: Registered protocol family 17
lib80211: common routines for IEEE802.11 drivers
registered taskstats version 1
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
▒Freeing init memory: 6268K
mount: mounting tmpfs on /dev failed: Invalid argument
_ _ _ _ _ _ _ _ _ _ _ _
\ _ _ _ _ _ ___
/ /__/ \ |_/
/ __ / - _ ___
_ _ _
/ / / \/ \_
__
___\
\___
[RCS]: /etc/init.d/S00devs
mknod: /dev/console: File exists
mknod: /dev/ttyAMA0: File exists
mknod: /dev/ttyAMA1: File exists
mknod: /dev/ttyS000: File exists
usb 1-1: new high speed USB device number 2 using hiusb-ehci
[RCS]: /etc/init.d/S01udev
udevd (437): /proc/437/oom_adj is deprecated, please use /proc/437/oom_score_adj instead.
[RCS]: /etc/init.d/S80network
IP: 192.168.233.233
BOOTP:
GATEWAY: 192.168.233.1
NETMASK: 255.255.255.0
HOSTNAME:
NETDEV: eth0
AUTOCONF:
[RCS]: /etc/init.d/S90init
PHY: himii:01 - Link is Up - 100/Full
==== Your model name is Opticam_O4 SENSOR=6 WIFI=1 LANGUAGE=2 MODELVERSION=14 MODELNUM=1 ====
==== Your input model name is Opticam_O4 ====
mem=190160
Hisilicon Media Memory Zone Manager
hi3518_base: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
Hisilicon UMAP device driver interface: v3.00
pa:8c000000, va:cc9c0000
load sys.ko for Hi3518...OK!
load viu.ko for Hi3518...OK!
ISP Mod init!
load vpss.ko ....OK!
load venc.ko for Hi3518...OK!
load group.ko for Hi3518...OK!
load chnl.ko for Hi3518...OK!
load h264e.ko for Hi3518...OK!
load jpege.ko for Hi3518...OK!
load rc.ko for Hi3518...OK!
load region.ko ....OK!
load vda.ko ....OK!
hi_i2c init is ok!
sha204 [sha204_init ,291]: sha204 driver init successful!
==== Your input Sensor type is 6 ====
* Board tools : ver0.0.1_20120501 *
[debug]: {source/utils/cmdshell.c:166}cmdstr:himm
0x20030030: 0x00000000 --> 0x00000005
[END]
acodec inited!
insert audio
==== Your input Wifi type is 1 ====
rtusb init rt3070STA --->
===>rt2870_probe()!
--> RTMPAllocAdapterBlock
packet> data offset = 152
packet> len offset = 80
packet> cb offset = 24
=== pAd = cce20000, size = 527720 ===
--> RTMPAllocTxRxRingMemory
<-- RTMPAllocTxRxRingMemory, Status=0
<-- RTMPAllocAdapterBlock, Status=0
NumEndpoints=7
BULK IN MaxPacketSize = 512
EP address = 0x81
BULK OUT MaxPacketSize = 512
EP address = 0x 1
EP address = 0x 2
EP address = 0x 3
EP address = 0x 4
EP address = 0x 5
EP address = 0x 6
STA Driver version-2.5.0.3
NVM is EFUSE
Allocate a net device with private data size=0!
Allocate net device ops success!
The name of the new ra interface is ra0...
RtmpOSNetDevAttach()--->
<---RtmpOSNetDevAttach(), ret=0
<===rt2870_probe()!
usbcore: registered new interface driver rt3070STA
ptz_init start ptz_state[1],HorPos[0],VerPos[0]
Jan 1 00:00:19 udevd-event[758]setup ptz gpio success
: udev_node_mknosetup zoom gpio success
d: mknod(/dev/ptptz_init end ptz_state[1],HorPos[-1],VerPos[-1],flag[0]
z, 020660, 10, 36) failed: File exists
Hisilicon Watchdog Timer: 0.01 initialized. default_margin=5 sec (nowayout= 0, nodeamon= 0)
mkdir: can't create directory '/mnt/mtd/app/modules': File exists
mkdir: can't create directory '/mnt/mtd/app/modules/extdrv': File exists
tar: can't open '/mnt/mtd/app/patch/patch.tar.xz': No such file or directory
set rtc time to system time
Auto login as root ...
(none) login: killall: devMng: no process killed
killall: codec: no process killed
killall: UDTMediaServer: no process killed
killall: webService: no process killed
killall: storage: no process killed
killall: FirmwareUpgrade: no process killed
killall: RtspServer: no process killed
killall: NVTService: no process killed
