for those that try to config foscam's new F41/FLC Floodlight cam in Blue Iris, you will have to do a manual setup. If you try to use the find/inspect feature of BI it will pick the wrong config. If you use any of the foscam settings you will get a stutter about every 3 secs in the video feed.
i blanked out the http ip and my user/password fields in the picture below. just remember you have to use port 88 (default unless you change it) when connecting to it. also note the rtsp port, onvif port, main profiles and onvif source " videosource_sourcetoken() "
