J jerryandthecats n3wb Nov 2, 2015 29 0 Oct 8, 2016 #1 Anyone using this Foscam on Blue Iris? I have 2 of these & never can get the motion detection correct - they always have detectins every minute r so, I have 3 other Foscams & they seem to do ok. Is there something I am doing wrong?
J jerryandthecats n3wb Nov 2, 2015 29 0 Oct 8, 2016 #3 Not sure of what settings you are referring, I am a novice at this.
fenderman Staff member Mar 9, 2014 36,891 21,417 Oct 8, 2016 #4 jerryandthecats said: Not sure of what settings you are referring, I am a novice at this. Click to expand... your recording and motion settings, in blue iris...they type of camera is irrelevant to blue iris, is simply receives a stream and processes it.
J jerryandthecats n3wb Nov 2, 2015 29 0 Oct 8, 2016 #5 Sorry I have since changed the settings & am trying object detection, but cud you give me some suggested setting for motion detection?
fenderman Staff member Mar 9, 2014 36,891 21,417 Oct 8, 2016 #6 jerryandthecats said: Sorry I have since changed the settings & am trying object detection, but cud you give me some suggested setting for motion detection? Click to expand... it will vary by the cameras view...post your settings..
J jerryandthecats n3wb Nov 2, 2015 29 0 Oct 8, 2016 #7 Ok thank you, I will try it again later. Appreciate your help
