Hi,
I need to recover some footage from an Atlantis a15-tx400 dvr, and I (wrongly) thought that the quickest way would be to remove the hdd from the dvr and plug it to my PC, rather then using the tedious usb method with the dvr UI. Unfortunately, even though I was able to access the file system through Diskinternal Linux Reader, the files inside are not readable, they are just a ton of 1GB files which don't have any extensions. I have even tried with a forensics software called DVR EXAMINER by Magnet but it can't decode the hdd, saying that it can't read RAYSHARP file system, or something like that.
The problem is that once I plugged the hdd back to the dvr the date was reset to 1/1/1970, and even after setting it back to the current date it still doesn't show any recorded footage.
I am sure the footage is still there since form the beginning I have unplugged all the cameras and I made sure nothing was written nor the hdd was formatted, but I can't find any way to extract the footage from it. Any suggestion would be really appreciated.
