loool man, no body but you started the image quality topic...
This entire thread is about stupid font that's abnormal, and its escalating to this camera being bad with IVS from my part, and some SmartPSS v2 crashing in general
It was a natural progression away from fonts once you, the OP, started then asking about: "I've been running one IPC-HFW3441E-SA installed outside for some days now and its horrible!!!! the audio quality settings are pathetic, the IVS is asleep, 50% miss rate, the time font is a joke, I would give this camera 0/10 to be honest, my old IPC-HFW4421E cams are out performing that cam loose hands! ... I'm starting to regret using dahua cameras and software due to constant issues since day one, starting with SmartPSS v2 that kept crashing on my server and any other pc acting as server when I playback video, dahua support from china spend days to try fix it, it was unsuccessful, it crashed on any pc....so it wasent hardware related, and therefore I'm still using SmartPSS v1
"Failed to start playback. NETSDK returns error" was the error"
Not that I did not post in this thread until after your post above, so I did not steer it way from "stupid font" as you steered it away when you said this camera IVS doesn't work, the audio is pathetic, etc. and I was offering up why that was the case.
Then that led to the discussion as to the camera you selected and what you are trying to accomplish and why it is failing with the newest algorithms compared to your older camera.
I have provided you with why this camera is not performing like your older one (problematic field of view, bad lighting, IVS setup issues using one line instead of zigzag or intrusion box), but it sounds like all you want to do is complain about the camera and say I took the thread off course, which in reality was getting you to the answers about why you are having problems with things outside of the font issue.
I'm done. Good luck...
