CCTVCam
- Sep 25, 2017
- 2,956
- 3,828
Yeah you will never get total back to front sharpness this side of variable aperture which doesn't exist.
As for the Arlo. Even though the colour balance looks better in the picture above, which is explained by the use of Auto and including too much sky in the Dahua picture, when you look at the Dahua picture, the gas cyclinder and rocks in front of it look more detail and sharper despite the colour inbalance and backlighting caused by the sky. The real difference will come about at night though. Try running 1/250th second (4ms) on the Arlo with gain below 50. I bet you can't see anything 2 feet out.
If variable aperture ever comes about. I'm sure f11-22 at day and f1.6 at night will sort it. The only problem then apart from the additional cost will be iris motor reliability / lifespan in cameras permanently exposed outdoors.
