I got my 4th camera as a turret with variable focal length so that I can determine what I might want for a few other places and decide if a fixed focal length would work, or a variable focal length. Is there anything that tells you what focal length the camera is currently set at? For instance, when I zoom, how do I know if I am at 6mm, or some other focal length (given same sensor size for comparable fixed focal length cameras). I'm using blue iris and also DMSS
