Floureon K9604-W bad flash
Sorry for double-posting, but figured I'd toss in an update. I noticed my error at the MMZ area showed a memory overlap. Kernel was allocating 145MB from start to end, which the MMZ began allocation at 140MB from the beginning of the kernel allocation. So I glanced back through and noticed my bootargs were different, indeed mine were mem=145 and ramdisk=8100, whereas yours matched. So I edited my bootargs to match yours and redid the process, viola. It booted with a 4 camera screen.
However: All the text is in chinese (not too terrible of a problem, just an inconvenience)... the issue, however is... I cannot login. It's all default (which is supposed to be admin/blank) yet it says wrong username/password. There seems to be no telnet daemon, or at least it isn't started so I can't telnet in. I cannot send commands via serial as it's still just receiving what's going on from the box (I was able to when it wasn't booting correctly).
Any idea how I can maybe mount the system without booting it and change the language/password via uboot?
EDIT: I MANAGED TO GET IN. I took the update file for 2.7.13 (dated the same as OPs original) renamed it to help.rom, and increased ramdisk to 8200. It booted in chinese, but I noticed on the serial connection that my old SSID flew by. Tried my old original login password and it accepted it. Managed to get it into english and through setup and seems to be working as normal again! Just finished readding my cameras to it.
Reactions: alastairstevenson
Sorry for necroing the thread, but I'm in the exact same boat, but I cannot get it to boot at all. The only info on the unit is that it's a K9604-W and when booting it, it sticks at "NVR Network Video Recorder System Initializing..."
Did you ever figure it out? All of my information (i.e. "printenv") matches yours (even my original error), and if I flash the help.rom I found from zosi that matches the model number, it APPEARS to boot, but still shows the splash screen and has a repeating error at the end.
This is what I get via serial now:
Code:
U-Boot 2010.06-dirty (Aug 15 2013 - 10:07:00)
Check spi flash controller v350... Found
Spi(cs1) ID: 0xC2 0x20 0x18 0xC2 0x20 0x18
Spi(cs1): Block:64KB Chip:16MB Name:"MX25L128XX"
In:    serial
Out:   serial
Err:   serial
Hit any key to stop autoboot:  0
16384 KiB hi_sfc at 0:0 is now current device
enable_mmu_accelerate
<<addr=0x84800000, size=0x40000, vobuf=0x8c000000>>
<<imgwidth=1024, imgheight=768, linebytes=2048>>
decode success!!!!
<<addr=0x84900000, size=0x40000, vobuf=0x8d000000>>
decode success!!!!
disable_mmu_accelerate
## Booting kernel from Legacy Image at 82000000 ...
   Image Name:   Linux-3.0.8
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    2472752 Bytes = 2.4 MiB
   Load Address: 80008000
   Entry Point:  80008000
## Loading init Ramdisk from Legacy Image at 81000000 ...
   Image Name:   JUAN root filesystem(21/01/2017)
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    7970816 Bytes = 7.6 MiB
   Load Address: 81000000
   Entry Point:  81000000
   Loading Kernel Image ... OK
OK
Starting kernel ...
Linux version 3.0.8 (root@lee) (gcc version 4.4.1 (Hisilicon_v100(gcc4.4-290+uclibc_0.9.32.1+eabi+linuxpthread)) ) #7 Sat Nov 19 08:35:53 CST 2016
CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: hi3520d
Memory policy: ECC disabled, Data cache writeback
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 36830
Kernel command line: mem=145M console=ttyAMA0,115200 root=0100 init=/linuxrc mtdparts=hi_sfc:512K(U),256K(E),256K(L),512K(C),2560K(K),12M(R) ramdisk_size=8100
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 145MB = 145MB total
Memory: 132436k/132436k available, 16044k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
    vmalloc : 0xc9800000 - 0xfe000000   ( 840 MB)
    lowmem  : 0xc0000000 - 0xc9100000   ( 145 MB)
    modules : 0xbf000000 - 0xc0000000   (  16 MB)
      .init : 0xc0008000 - 0xc002d000   ( 148 kB)
      .text : 0xc002d000 - 0xc0620000   (6092 kB)
      .data : 0xc0620000 - 0xc064e2e0   ( 185 kB)
       .bss : 0xc064e304 - 0xc06aa510   ( 369 kB)
SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:128 nr_irqs:128 128
sched_clock: 32 bits at 82MHz, resolution 12ns, wraps every 52060ms
Console: colour dummy device 80x30
Calibrating delay loop... 1318.91 BogoMIPS (lpj=6594560)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
devtmpfs: initialized
xor: measuring software checksum speed
   arm4regs  :  1071.600 MB/sec
   8regs     :   802.800 MB/sec
   32regs    :   851.200 MB/sec
xor: using function: arm4regs (1071.600 MB/sec)
NET: Registered protocol family 16
hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step.
hw-breakpoint: maximum watchpoint size is 4 bytes.
Serial: AMBA PL011 UART driver
uart:0: ttyAMA0 at MMIO 0x20080000 (irq = 40) is a PL011 rev2
console [ttyAMA0] enabled
uart:1: ttyAMA1 at MMIO 0x20090000 (irq = 41) is a PL011 rev2
uart:2: ttyAMA2 at MMIO 0x200a0000 (irq = 42) is a PL011 rev2
uart:3: ttyAMA3 at MMIO 0x200b0000 (irq = 43) is a PL011 rev2
bio: create slab <bio-0> at 0
raid6: int32x1     32 MB/s
raid6: int32x2     55 MB/s
raid6: int32x4     75 MB/s
raid6: int32x8    101 MB/s
raid6: using algorithm int32x8 (101 MB/s)
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
cfg80211: Calling CRDA to update world regulatory domain
Switching to clocksource timer1
FS-Cache: Loaded
CacheFiles: Loaded
NET: Registered protocol family 2
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Trying to unpack rootfs image as initramfs...
rootfs image is not initramfs (junk in compressed archive); looks like an initrd
Freeing initrd memory: 7784K
NetWinder Floating Point Emulator V0.97 (double precision)
L2cache cache controller enabled
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
DLM installed
squashfs: version 4.0 (2009/01/31) Phillip Lougher
NTFS driver 2.1.30 [Flags: R/W].
fuse init (API version 7.16)
SGI XFS with security attributes, large block/inode numbers, no debug enabled
msgmni has been set to 273
alg: No test for stdrng (krng)
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
io scheduler noop registered
io scheduler deadline registered (default)
io scheduler cfq registered
brd: module loaded
loop: module loaded
Loading iSCSI transport class v2.0-870.
SCSI Media Changer driver v0.25
ahci: SSS flag set, parallel bus scan disabled
ahci ahci.0: AHCI 0001.0200 32 slots 2 ports 3 Gbps 0x3 impl platform mode
ahci ahci.0: flags: ncq sntf stag pm led clo only pmp pio slum part ccc sxs boh
scsi0 : ahci_platform
scsi1 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x10080000-0x1008ffff] port 0x100 irq 52
ata2: SATA max UDMA/133 mmio [mem 0x10080000-0x1008ffff] port 0x180 irq 52
Spi id table Version 1.22
SPI FLASH start_up_mode is 3 Bytes
Spi(cs1):
Block:64KB
Chip:16MB
spi size: 16MB
chip num: 1
6 cmdlinepart partitions found on MTD device hi_sfc
Creating 6 MTD partitions on "hi_sfc":
0x000000000000-0x000000080000 : "U"
0x000000080000-0x0000000c0000 : "E"
0x0000000c0000-0x000000100000 : "L"
0x000000100000-0x000000180000 : "C"
0x000000180000-0x000000400000 : "K"
0x000000400000-0x000001000000 : "R"
Fixed MDIO Bus: probed
ata1: SATA link down (SStatus 0 SControl 300)
himii: probed
ata2: SATA link down (SStatus 0 SControl 300)
Invalid HW-MAC Address: 00:00:00:00:00:00
Set Random MAC address: 5A:E5:51:22:D0:10
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
PPP BSD Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256).
CSLIP: code copyright 1989 Regents of the University of California.
SLIP linefill/keepalive option.
usbmon: debugfs is not available
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
hiusb-ehci hiusb-ehci.0: HIUSB EHCI
hiusb-ehci hiusb-ehci.0: new USB bus registered, assigned bus number 1
hiusb-ehci hiusb-ehci.0: irq 53, io mem 0x100b0000
hiusb-ehci hiusb-ehci.0: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
hiusb-ohci hiusb-ohci.0: HIUSB OHCI
hiusb-ohci hiusb-ohci.0: new USB bus registered, assigned bus number 2
hiusb-ohci hiusb-ohci.0: irq 54, io mem 0x100a0000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver ums-alauda
usbcore: registered new interface driver ums-cypress
usbcore: registered new interface driver ums-datafab
usbcore: registered new interface driver ums_eneub6250
usbcore: registered new interface driver ums-freecom
usbcore: registered new interface driver ums-isd200
usbcore: registered new interface driver ums-jumpshot
usbcore: registered new interface driver ums-karma
usbcore: registered new interface driver ums-onetouch
usbcore: registered new interface driver ums-realtek
usbcore: registered new interface driver ums-sddr09
usbcore: registered new interface driver ums-sddr55
usbcore: registered new interface driver ums-usbat
usbcore: registered new interface driver usbserial
USB Serial support registered for generic
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial Driver core
USB Serial support registered for GSM modem (1-port)
usbcore: registered new interface driver option
option: v0.7.2:USB Driver for GSM modems
mousedev: PS/2 mouse device common for all mice
md: linear personality registered for level -1
md: raid0 personality registered for level 0
md: raid1 personality registered for level 1
md: raid10 personality registered for level 10
md: raid6 personality registered for level 6
md: raid5 personality registered for level 5
md: raid4 personality registered for level 4
md: multipath personality registered for level -4
md: faulty personality registered for level -5
device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: [email protected]
device-mapper: multipath: version 1.3.0 loaded
device-mapper: multipath round-robin: version 1.0.0 loaded
device-mapper: multipath queue-length: version 0.1.0 loaded
device-mapper: multipath service-time: version 0.2.0 loaded
device-mapper: dm-log-userspace: version 1.1.0 loaded
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
TCP cubic registered
Initializing XFRM netlink socket
NET: Registered protocol family 17
NET: Registered protocol family 15
802.1Q VLAN Support v1.8
sctp: Hash tables configured (established 4096 bind 8192)
lib80211: common routines for IEEE802.11 drivers
md: Waiting for all devices to be available before autodetect
md: If you don't use raid, use raid=noautodetect
md: Autodetecting RAID arrays.
md: Scanned 0 and added 0 devices.
md: autorun ...
md: ... autorun DONE.
RAMDISK: squashfs filesystem found at block 0
RAMDISK: Loading 7782KiB [1 disk] into ram disk...
usb 1-2: new high speed USB device number 2 using hiusb-ehci
done.
VFS: Mounted root (squashfs filesystem) readonly on device 1:0.
devtmpfs: mounted
Freeing init memory: 148K
starting pid 662, tty '': '/etc/init.d/rcS'
            _ _ _ _ _ _ _ _ _ _ _ _
            \  _  _   _  _ _ ___
            / /__/ \ |_/
           / __   /  -  _ ___
  _ _ _ _/ /  /  \_/  \_ ______
___________\___\__________________
[RCS]: /etc/init.d/S00devs
mknod: /dev/console: File exists
mknod: /dev/ttyAMA0: File exists
mknod: /dev/ttyAMA1: File exists
[RCS]: /etc/init.d/S01udev
udevd (673): /proc/673/oom_adj is deprecated, please use /proc/673/oom_score_adj instead.
Jan  1 00:00:04 udevd-event[989]: udev_node_mknod: unlink(/dev/pktcdvd) failed: Is a directory
Jan  1 00:00:04 udevd-event[989]: udev_node_mknod: mknod(/dev/pktcdvd, 020660, 10, 58) failed: File exists
[RCS]: /etc/init.d/S02pppd
[RCS]: /etc/init.d/S03pppoe
PPPoE config
[RCS]: /etc/init.d/S80network
[RCS]: /etc/init.d/S81toe
[RCS]: /etc/init.d/S98
[RCS]: /etc/init.d/S99
mount dir('/media/usb1') isn't exist now!
check sda...
sda... not found
check sdb...
sdb... not found
check sdc...
sdc... not found
check sdd...
sdd... not found
check sde...
sde... not found
check sdf...
sdf... not found
check sdg...
sdg... not found
check sdh...
sdh... not found
check sdi...
sdi... not found
check sdj...
sdj... not found
check sdk...
sdk... not found
check sdl...
sdl... not found
restore flag 1 not found.
enable log not found.
enable log2 not found.
enable disk log not found.
rmem_default:
108544
rmem_max:
108544
min_free_kbytes:
1535
Hisilicon Media Memory Zone Manager
ERROR: Conflict MMZ:
PHYS(0x88C00000, 0x8FFFFFFF), GFP=0, nBYTES=118784KB,   NAME="anonymous"
MMZ conflict to kernel memory (0x80000000, 0x890FFFFF)
Add MMZ failed: PHYS(0x88C00000, 0x8FFFFFFF), GFP=0, nBYTES=118784KB,   NAME="anonymous"
hi3520D_base: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
Hisilicon UMAP device driver interface: v3.00
load sys.ko ...OK!
insmod: can't insert './hi_module/hi3520D_tde.ko': Operation not permitted
hi3520D_dsu: Unknown symbol TdeOsiMbBlit (err 0)
hi3520D_dsu: Unknown symbol TdeOsiMb2Mb (err 0)
hi3520D_dsu: Unknown symbol TdeOsiCancelJob (err 0)
hi3520D_dsu: Unknown symbol TdeOsiOpen (err 0)
hi3520D_dsu: Unknown symbol TdeOsiOsd2Mb (err 0)
hi3520D_dsu: Unknown symbol TdeOsiEndJob (err 0)
hi3520D_dsu: Unknown symbol TdeOsiClose (err 0)
hi3520D_dsu: Unknown symbol TdeOsiMbFill (err 0)
hi3520D_dsu: Unknown symbol TdeOsiGetFiltParam (err 0)
hi3520D_dsu: Unknown symbol TdeOsiBeginJobEx (err 0)
hi3520D_dsu: Unknown symbol TdeOsiSetFiltParam (err 0)
hi3520D_dsu: Unknown symbol TdeOsiMemRequest (err 0)
hi3520D_dsu: Unknown symbol TdeOsiRegisterMemManage (err 0)
hi3520D_dsu: Unknown symbol TdeOsiGetJobNumInFifo (err 0)
insmod: can't insert './hi_module/hi3520D_dsu.ko': unknown symbol in module, or unknown parameter
load venc.ko ...OK!
load group.ko ...OK!
load chnl.ko ...OK!
load h264e.ko ...OK!
load rc.ko ...OK!
load jpege.ko ...OK!
load viu.ko ...OK!
load vou.ko ....OK!
load vpss.ko ....OK!
load vda.ko ....OK!
load region.ko ....OK!
hifb: Unknown symbol TdeOsiCancelJob (err 0)
hifb: Unknown symbol TdeOsiOpen (err 0)
hifb: Unknown symbol TdeOsiEndJob (err 0)
hifb: Unknown symbol TdeOsiClose (err 0)
hifb: Unknown symbol tde_get_procentry (err 0)
hifb: Unknown symbol TdeOsiBlit (err 0)
hifb: Unknown symbol TdeOsiBeginJob (err 0)
hifb: Unknown symbol TdeOsiEnableRegionDeflicker (err 0)
insmod: can't insert './hi_module/hifb.ko': unknown symbol in module, or unknown parameter
load vdec.ko ....OK
load vhd firmware.ko OK
load hdmi.ko ....OK!
jpeg: Unknown symbol tde_get_procentry (err 0)
insmod: can't insert './hi_module/jpeg.ko': unknown symbol in module, or unknown parameter
Hisilicon Watchdog Timer: 0.01 initialized. default_margin=60 sec (nowayout= 0, nodeamon= 1)
HI3515 base @ 17:42:44 Jan 21 2017
GPIO I2C for HI35xx @ 17:42:44 Jan 21 2017
GPIO_MODE:RMII disable
tmpClkV=0x002547ae
GPIO_MODE:GPIO_PLAT_TYPE8
PERI_CRG_REG51:addr=0x200300cc, val=0x00000002
IO_CONFIG_REG(38):addr=0x200f0098, val=0x00000000
IO_CONFIG_REG(39):addr=0x200f009c, val=0x00000000
IO_CONFIG_REG(40):addr=0x200f00a0, val=0x00000000
IO_CONFIG_REG(41):addr=0x200f00a4, val=0x00000000
IO_CONFIG_REG(42):addr=0x200f00a8, val=0x00000000
IO_CONFIG_REG(43):addr=0x200f00ac, val=0x00000000
IO_CONFIG_REG(44):addr=0x200f00b0, val=0x00000000
IO_CONFIG_REG(45):addr=0x200f00b4, val=0x00000000
IO_CONFIG_REG(46):addr=0x200f00b8, val=0x00000001
IO_CONFIG_REG(47):addr=0x200f00bc, val=0x00000001
IO_CONFIG_REG(48):addr=0x200f00c0, val=0x00000000
IO_CONFIG_REG(49):addr=0x200f00c4, val=0x00000000
IO_CONFIG_REG(50):addr=0x200f00c8, val=0x00000000
GPIO Init Succeed!
input: keypad as /devices/virtual/input/input0
Keypad for HI3515 @ 17:42:43 Jan 21 2017
input: irda as /devices/virtual/input/input1
Irda for HI3515 @ 17:42:44 Jan 21 2017
do you want to run app.out(y or n)?
Found keypad@event0.
[pre_run_app] cp
[pre_run_app] chmod
[pre_run_app] running...
pre_run_app.sh end
[pre_run_app] finish
JPROCESS::CRIT: [ja_process.c: 677] new ok@parent
JPROCESS::CRIT: [ja_process.c: 663] new ok@child
JPROCESS::CRIT: [ja_process.c: 497] JPROCESS proc....
JPROCESS::CRIT: [ja_process.c: 584] JPROCESS proc....
STATIC->[GUIStatic]:154 lang0:name=English, file=0_english.fnt
STATIC->[GUIStatic]:154 lang1:name=Chinese_Mainland, file=1_chinese_mainland.fnt
STATIC->[GUIStatic]:154 lang2:name=Chinese_Hongkong, file=2_chinese_hongkong.fnt
STATIC->[GUIStatic]:154 lang3:name=Chinese_Taiwan, file=3_chinese_taiwan.fnt
STATIC->[GUIStatic]:154 lang4:name=Korean, file=4_korean.fnt
STATIC->[GUIStatic]:154 lang5:name=Japanese, file=5_japanese.fnt
STATIC->[GUIStatic]:154 lang6:name=Arabic, file=6_arabic.fnt
STATIC->[GUIStatic]:154 lang7:name=Persian, file=7_persian.fnt
STATIC->[GUIStatic]:154 lang8:name=Hebrew, file=8_hebrew.fnt
STATIC->[GUIStatic]:154 lang9:name=Portuguese, file=9_portuguese.fnt
STATIC->[GUIStatic]:154 lang10:name=Spanish, file=10_spanish.fnt
STATIC->[GUIStatic]:154 lang11:name=Hungarian, file=11_hungarian.fnt
STATIC->[GUIStatic]:154 lang12:name=Russian, file=12_russian.fnt
STATIC->[GUIStatic]:154 lang13:name=French, file=13_french.fnt
STATIC->[GUIStatic]:154 lang14:name=German, file=14_german.fnt
STATIC->[GUIStatic]:154 lang15:name=Thai, file=15_thai.fnt
STATIC->[GUIStatic]:154 lang16:name=Vietnamese, file=16_vietnamese.fnt
STATIC->[GUIStatic]:154 lang17:name=Turkish, file=17_turkish.fnt
STATIC->[GUIStatic]:154 lang18:name=Italian, file=18_italian.fnt
STATIC->[GUIStatic]:154 lang19:name=Danish, file=19_danish.fnt
STATIC->[LoadLangFile]:81 tmp_path=static/0_english.fnt
STATIC->[LoadLangFile]:88 file=0_english.fnt flag=feefface count=1129
wait for app to prepare environment....
get value device_model failed
get value main_stream failed
ENVIRONMENT: check 2nd crc = f188
INFO : 1368:[DVR_InitTestMode:1043]@17:18:01  enter main application
Secure CRC ERROR!
killall: upnp_server: no process killed
NK_PROCESS::CRIT: [ja_process.c: 167] PROCESS(1372) wait done
Device Name: NVR
Device Model: K9604-W
Device ID: NS711041404546
Device ID KEY: 00000000000000000000000000000000
Device Software Version: 2.5.5 0
Camera: 4
Audio: 4
Sensor: 4
Alarm: 1
Hard Disk Driver: 4
Series Code: NS
DEBUG: 1368:[dvr_init_prepare:1711]@17:18:03  begin
DEBUG: 1368:[dvr_init_prepare:1733]@17:18:03  end
DEBUG: 1368:[NK_InitSearchConfig:299]@17:18:03  Successful load the ipc default list.
DVR->[DVR_Init]:1905 isNeedRecoverEnv = 0,No change env Need to Recover.
DEBUG: 1368:[dvr_init_keep_proc:1631]@17:18:03  begin
filesize = 0
TZONE_DEBUG: 1368:[TZONE_set_index:334]  before setup time now: Fri Dec 31 17:18:04 2004
TZONE_DEBUG: 1368:[TZONE_set_index:336]  gmttime: Fri Dec 31 17:18:04 2004
TZONE_DEBUG: 1368:[TZONE_set_index:338]  localtime: Fri Dec 31 17:18:04 2004
TZONE_DEBUG: 1368:[TZONE_set_index:342]  set system timezone to +08:00 (13, 28800)
TZONE_DEBUG: 1368:[set_system_tzone_offset2:247]  set TZ ENV to : GMT-08:00 success !
TZONE_DEBUG: 1368:[set_system_tzone_offset2:255]  tzname:GMT/ tzone:-28800 daylight:0
TZONE_DEBUG: 1368:[TZONE_set_index:353]      GMT Time: Fri Dec 31 17:18:04 2004
TZONE_DEBUG: 1368:[TZONE_set_index:354]          Local Time: Sat Jan  1 01:18:04 2005
TZONE_DEBUG: 1368:[TZONE_set_index:356]  time now: Sat Jan  1 01:18:04 2005
TZONE_DEBUG: 1368:[TZONE_set_index:358]  gmttime: Fri Dec 31 17:18:04 2004
TZONE_DEBUG: 1368:[TZONE_set_index:360]  localtime: Sat Jan  1 01:18:04 2005
DVR::INFO: [       dvr.c:2016] start in normal mode (0)!
DEVIDE_MODE::INFO: [nk_device_info.c:  77] nk_DeviceInfoInit succeed filter_enable = 0, manufacturer = Normal!
DVR->[DVR_Init]:2075 vga [1280,1024] cvbs [704,576]
TIMETICK->[timetick.c]:240 task list is empty
TIMETICK->[timetick.c]:112 TIMETICK pid=1368 tid=41f1f4c0 begin
Init Serial Code: NS711041404546
SYSTEM->[SYSTEM_SetTime]:640 RTC time is Sat Jan  1 01:18:04 2005
   --GMT Time: Fri Dec 31 17:18:04 2004
    --Local Time: Sat Jan  1 01:18:04 2005
     --SYS CUR PTS: 1104513484132155  Sat Jan  1 01:18:04 2005
system.c->473 HI_MPI_VB_Init() failed->0xa001800c
JPROCESS::ERROR: [ja_process.c: 519] read failed@errno:22
starting pid 1384, tty '': '/sbin/ifconfig lo 127.0.0.1 up'
starting pid 1385, tty '': '/sbin/route add -net 127.0.0.0 netmask 255.0.0.0 lo'
starting pid 1386, tty '': '-/bin/sh'
Welcome to HiLinux.
Initialize internal port.
Set server on unix domain ok.
Subthread stack size:307200
Start thread code:0 id:400db000
SOCK-ERROR: connect failed @ SOCK_ERR=2DVRCOMM: connect 127.0.0.1:9012 failed, after 5 seconds retry.
# JPROCESS::ERROR: [ja_process.c: 519] read failed@errno:22
parent process exited!
[new_intf/gui_stage_sdl_lite.cpp: 213] resolution = 2
gui-app sync retry 1
gui-app sync retry 2
gui-app sync retry 3
gui-app sync retry 4
gui-app sync retry 5
gui-app sync retry 6
repeat error at end until I unplug it. Did you find the proper file or a way to make it work?
