Hi everyone, i am new here. Here is my issue:
I bought this H.264 Network DVR back in 2014.
I need to connect using telnet to DVR, i got telnet on pc, the DVR is connected to router and ip pings with no problem, i can use the web browser interface connecting trough local ip, but when i try to connect using telnet i just can't login because of unknown credentials (login and password).
I already try to contact [email protected] but i got no response, seems like manufacturer is disappeared as i can't find a way to contact them; either a website, a pdf manual download link, a firmware update support... nothing found in internet
Anyway, there is a chance to know user and password to login using telnet?
This is what happened when i try to connect using telnet:
After "open <ip>" command
This happen when i try to use credentials user: root, password: xc3511
Next uploded photos contains model code and other info about the DVR
