Hi,
I have flir ip camera that wont up.
i connect to rs232 and see this output :
Any idea ???
Code:
U-Boot 2010.06-svn2635 (May 28 2015 - 10:21:40)
I2C: ready
DRAM: 256 MiB
gBootLogPtr:80580008.
NAND: HW ECC BCH8 Selected
128 MiB
partition file version 2
rootfstype squashfs root /dev/mtdblock7
TEXT_BASE:80a00000
Net: Ethernet clocking: 0x52
Detected MACID:0:40:7f:79:6e:73
B50612E found
link up on port 0, speed 100, full duplex
Using cpsw device
TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1
Download Filename 'upgrade_info_7db780a713a4.txt'.
Download to address: 0x84000000
Downloading:
Retry count exceeded; starting again
Try again use backup_serverip
*** ERROR: `serverip' not set
Failed to get info.txt
Fail to get info file!
Init error!
Using cpsw device
Download Filename 'failed.txt'.
Download to address: 0x81000000
Downloading:
## Booting kernel from Legacy Image at 81000000 ...
Image Name: uImage
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 4588224 Bytes = 4.4 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ...OK
OK
can't find corresponding entry
fail to resolve
fail to load bootargsParameters.txt
fail to load bootargsParameters.txt file
get bootargs info failed
cmdLine console=ttyO0 rootfstype=squashfs root=/dev/mtdblock7 init=/linuxrc mem=144M vram=4M notifyk.vpssm3_sva=0xBFD00000 cmemk.phys_stazt=0x89000000 cmemk.phys_end=0x8a000000 cmemk.allowOverlap=1
crashflasg:1, logmagic:54410011.
Starting kernel ...
Any idea ???
