Fixing focus on IPC-COLOR4K-X
bp2008
Staff member
Mar 10, 2014
12,886
14,481
USA
I bought a refurbished IPC-COLOR4K-X from Andy last year and its focus was not great. Then for some reason it got worse over time.
So I took it apart today and was able to fix the focus easily.
1. Take off front panel of camera to expose 4 screws.
2. Unscrew 4 screws to open camera case.
3. With a knife, break off blobs of hot glue from the lens (top and bottom).
4. Use a H1.5 hex driver to loosen two screws that the hold the lens in place (sides).
5. Twist lens to change focus.
This made an incredible difference in the image quality.
BEFORE:
AFTER:
