FIXED - Clip: Disk Not Ready / Check folder exists with adequate free space
singularity42
Jan 21, 2020
53
16
MN
This issue all the sudden started about 3-4 days ago. BI has been running fine for about 8 years now, through 2 different Unraid systems. Now it will not record anything due to this issue, along with not recording snapshots due to: "Check folder exists with adequate free space"
There are 3 shares and it has this issue with all of them. 1 for Archived long term data, 1 for current live records, 1 for alerts/snapshots.
After checking half a dozen google links/threads, here is what Ive tried so far:
  • Repair DB
  • Make sure BI service isnt running
  • Verify there is plenty of space on share (5TB)
  • Unmounted share and remounted, then connected them back to BI
  • Deleted all videos, snapshots, alerts, rescan DB
  • Deleted all DBs, restarted BI
  • Rebooted BI
  • Shutdown entire Unraid array and rebooted
  • Made sure shares are writable and readable from within Windows
  • Ran chkdisk (no issues)
  • Rolled back to previous version of BI
Short of deleting the entire VM, or wiping the shares and recreating them, Im fresh out of ideas.. Any other suggestions?
Code:
Support data:
Version: Release 5.5.9.3 x64  (6/29/2022)
Service: No
Support: Extended
Expires: 11/25/2022 5:54:23 PM
WAN: redacted
OS: Windows Server 2016 Standard
CPU: Intel(R) Xeon(R) CPU E5-2667 v3 @ 3.20GHz [4%]
RAM: 613.9M/15.9G
Clips: 0 items, 0B/4.98T
Storage: !! Z: -4.98T
try rolling back even farther in BI?
I completely deleted the shares and recreated them. No luck. Its like BI just can't read the disks correctly:
strange. weird. frustrating to say the least.
I don't know where to start that you haven't been already.
Short of reinstalling Windows and BI.
What a pain that would be.
Do you have a Drive C:\ Image being backed up that you could revert to?
I'm running a free version of Macrium reflect on W-11 with a daily differential backup being written to a folder on my surveillance drive.
Once in a blue moon it makes me look organized :)......
I have saved the running image of Win10 for this PC should I need to revert if BI gets cynical with w-11.
It could be thats it's not a software issue. and a backup wouldn't help.
Hard to sort out.
Ya, its aggravating. Im going to probably just install a fresh Windows VM and BI. Hopefully the settings and camera exports maintain most everything I need.
I wiped all of BI5, reinstalled, same issue. Rebuilding VM is next on the list, I guess. No response from email support :(
You probably did this, but did you reformat the storage drives and assure that your computer recognizes them and are designated as a drive? It almost looks more like your system doesn't recognize them, so BI won't?
Its connected to a NAS, so the shares are spread over many drives. No other services or vms I run have any issues. I did attempt to delete the shares and create new ones, that didnt work either. When they were deleted, and remapped to the local Windows OS, I verified they are readable and writeable by the same user running BI (Administrator).
Something new I figured out. If I create a new share, then map it up, BI recognizes it and can write to it for a very short period of time. Then it goes back to Unknown size and Clip: Disk Not Ready issues.
