- Mar 2, 2016
- 26
- 5
I am getting really annoyed looking at fisheye camera specifications. The amount of bullshit in the fisheye camera industry is piling up, and I'm getting tired of shoveling through it.
If you have a perfectly circular lens view on a rectangular sensor, you should not claim the full sensor resolution as the usable resolution. But that is what many companies are doing.
Hikvision DS-2CD6362F-I 6MP IR Panaramic 180/360 Degree, Indoor
Max resolution: 3072 x 2048
360 degree view.
Actual resolution is the radius of the circle squared times pi
1024 (y axis radius) squared (1048576) times pi = 3294198 actual (3.3MP)
Usable pixel coverage is 52%. (What a waste of an HD rectangular image sensor.)
The only time your fisheye resolution is really better than this is when the view is not perfectly circular, either due to oval lens optics or because the circular view overlaps the edges of the sensor.
Hikvision DS-2CD2942F-IS 4Mp Indoor D/N Network Fisheye Camera
Max resolution: 4 megapixel (2560 x 1440)
Angle of view: 186°(horizontal), 106°(vertical)
Caculating pixel coverage of that was quite a pain but it is about 81.97% sensor coverage, not including the reflected / blur zone around the edge.
http://www.regentsprep.org/regents/math/geometry/gp16/circlesectors.htm
http://www.blocklayer.com/protractor-printeng.aspx
2560 * 1440 = 3686400 * 81.97% = 3021742 (3.0 MP)
.... so:
- the "4MP" fisheye is really 3.0 MP usable, with a long rectangular view
- the "6MP" circular fisheye is really 3.3 MP usable, or just 9% higher detail
360 degree view.
.... so:
