Hi all,
Looking to DIY some IP cams - I have a gen 6 i5 windows 10 machine running 24/7 doing backups, running a Plex server (family photos only, doesn't do anything major like transcoding) and an OPNSense (nano build) VM for VPN in/out and some basic routing. As it's not too heavily loaded and it's on all the time it makes sense to use it for DVR also.
Looking at five cameras, 1080p on four of them and preferably 4k (wide angle, 2.8mm) for the remaining one. Would like the ability to 'arm' and 'disarm' motion detection for all cameras in a similar fashion to a burglar alarm so that I can get a push notification/email/SMS or similar to alert me of any motion.
What's your thoughts on the most efficient way of running them? What's the right software? I was thinking straight stream copy in the camera's native formats (H264/265) to HDD and let the cameras do their own motion processing so that the CPU in my PC isn't going mad. Then I was going to set up the second stream on the cameras for on-demand live viewing remotely/via mobile app directly to the cameras as opposed to via the DVR software, so it doesn't have to do any transcoding.
Does all this sound plausible? A few unknowns:
- How would I get push notifications? Can the Hikvision cameras do emails?
- If I'm configuring each camera separately for alerting me, how can I 'arm' or 'disarm' the alerts easily?
- Is it possible for the cameras to attach the clip(s) triggering the alert to email or similar? I'm just thinking for example if I have a break in and the PC goes, I'd like to keep the footage.
Thanks!
Thanks!
