- Apr 1, 2018
- 22
- 3
Great thanks! I was able to get 5 lines routed into the garage and into a junction box. All lines in the garage terminate to a female cat6 snap in. The other end are all bundled and strapped to the rafters and ready to be plugged into the nvr once mounted. All I need to do for the first camera is to route the wire through the brick and patch into the panel in the garage. I'm going to use the mounts that tonyR suggested. I'm going to place it on the brick because the soffit by the door just seemed too high as suggested.
