First Impressions of the new AI LPR camera
dschur
Sep 20, 2024
5
5
Chicago, IL
wanted to share this here... its a game changer
full thread with images on the UI forum
I wanted to share my initial impressions of Ubiquity’s newly released AI LPR camera - particularly how it does for me at nighttime LPR.
For a little background, I have been running an Axis Q1656-DLE camera (paired to an AI port) pointed North and a Ubiquiti AI Pro pointed South. Both are mounted directly at the side of a residential street - pointed about 20 degrees into the traffic lanes. The speed limit on the street is 25MPH, but traffic is typically in the 26-30 range with about 10% going 30-35MPH. This street has about 150 car/plates per day and 30 or so of which are in the dark. The AI pro has done great during the day on LPR, but at night as everyone knows it detects motion, car, people, etc, but never 1 plate at night. The Axis does equally well to the Ai Pro during the day (via the AI Port in Protect), but at night as it is night LPR optimized (dark image) it goes blind at night so I had to resort to it’s onboard software at night for LPR.The Axis software is horrible - it only catches a single static image and the UI is 10 years out of date. Keep in mind the Axis is a $2500 camera (I didn’t pay that) and the LPR software license on it is another $600. My particular Axis also has integrated Radar - a truly unique feature that adds speed logging to recorded video and images. So I’m comparing the AI LPR against probably the gold standard of LPR - a $3000 Axis setup.
I got the new AI LPR shipped overnight as soon as it became available and installed it yesterday afternoon. Directly next to the Axis and with the same FOV. Only default setting I changed was “LPR Night Vision”, I do not have it set to “LPR Dedicated” (it still detects people, dogs, cars, barking, speaking, etc). Optical Zoom is maxed at 3X and pointed in a good area for plates. Initially I was skeptical of the AI LPR’s night possibilities in the software as “LPR night vision” is the only tweaking for Night LPR. As someone who has spent countless hours tweaking at a nano detail level the night settings on the Axis like Contrast, Local Contrast, Tone Mapping, IR Threshold, Max Shutter, Max Gain, etc I was “stuck” with just installing the AI LPR and hoping for the best?
The daytime LPR was great as I anticipated - on par with the Axis and the AI Pro - capturing 100%. Nothing new there so it looked good so far.
And then the sun set and darkness descended last night…
As the hours went through the night the AI LPR continued to shine. It captured every single plate! 100%! 37/37 in the 12 hours of dark. Combined with the great protect software, the improved timeline frame-by-frame viewer with keyboard support, it really shines. The plates are all crystal clear and easily readable.
I am super impressed by the AI LPR in my situation - it has delivered everything I was hoping for. I will likely sell the Axis camera (my keep it for the Radar speed recording only) and I’ll free up the AI Port that was on the Axis for my Overview Camera (Reolink Duo 3) that captures 180 degrees eagle view of the whole street. I’ll also get another AI LPR to replace the South AI Pro, freeing that up to use elsewhere.
All is not perfect in Protect yet for LPR however - as many know the OCR of the plates itself is still a little wonky - misreading 1 or 2 characters quite regularly (typically at the front/end of the plate, and usually letters withe mistaken for numbers or dropped altogether), and I think there is a hardcoded plate length (4) and it seems to want at least 1 or 2 numbers (regardless of plate length). That said, the plates are detected and capture is good (the important part) and I’m hopeful Ubiquiti will improve the OCR now that the hardware is in place. That said, manual review is super easy to do when needed and perfectly clear (it’s sad that you can’t save corrections though)
All-in-all, this camera is a game changer IMO. A huge kudos to the Ubiquiti engineers - you clearly spent a lot of time dissecting what makes night time LPR great and expertly encoded it into your first LPR camera out of the gate. It doesn’t bother me that it’s all just behind one checkbox - it works perfectly and out of the box - no messing around.
I’ll report back after this setup runs for a week or so. If I don’t in the interim, it’s safe to assume it’s still working 100% at night.
Until then, I’ll leave you with a set of images, in pairs (of the same plate) where the first is the Axis image recorded at the time of LPR (the "before") and the second is a screenshot of the AI Pro at the same time (the "after"). As you can see the AI pro is much clearer (same sensor size, but resolution is 8MP vs 4MP on the Axis).
Thanks for the report.
It will probably not work for non reflective plates in the lpr night vision mode except maybe very close
In the night mode, there is a long/band pass IR filter that cuts visible light and improves the clarity of the reflective
license plates
The dahua doesnt have this filter?
How much $$$ was it?
Serious question: I wonder out loud if for the average home user if there is any real benefit to having a camera that does OCR/ANPR and creates a database of plates...
I know its not an image quality issue as a $200 5241-Z12 will capture great images, and if you have your IVS/MD triggers set right, misses close to Zero.
(100-120ft)
HOAEntrP2P_EntTag_main_20250131003410_@2.jpg HOARearP2P_Tag_main_20250130135355_@3.jpg HOAEntrP2P_EntTag_main_20250130122301_@2.jpgHOAEntrP2P_EntTag_main_20250130003119_@2.jpg
So with a companion Overview camera I can get color and a better idea of the vehicle make/model etc at night as well as day of course.
And with a AI enabled NVR I can display the vehicles with thumbnails to pick out visually. (My older NVR doesnt do the ANPR but newer models can)
So it seems like the advantage would be the database. If I KNOW a plate # I could search it. And IF it has a blacklist tied to some type of alert, I guess it could send me a push message or email saying "Previously Defined Bad Guy Plate came by"
In any other case it would be the same with or without OCR/database/blacklist, manually looking based on a known time frame and some knowledge that an event occurred ..?
I personally prefer having the database just for that reason, being able to look up a plate if I want to see if that vehicle has been around in the past week, 2 weeks, whatever.
For myself, it's helped 5 or 6 times to narrow down when a vehicle has been stoles, break in, etc...
Now, do you need a 431/437 ANPR that just does plates? Probably not for the average person. But I like mine.
I think for someone like yourself, the 7x cam would be a great fit. Not only does it capture plates, but face captures, etc... shows it up on the screen and can look up plates or faces in the AI search.
I believe blue iris does a lot of the same things?
Actually with VMD enabled I can get that stuff with the 7 series cam. And agree with you that’s prob my next purchase
POE+ and only 3x optical zoom. The 12mm focal length alone is a game breaker for most of us. Only those that can mount this at the road can really take advantage of it. And do you have to run their crappy controller software to interact with this?
Reactions: samplenhold
Yeah I don't want to scrub lot's of video LOL, so the database is nice to see a questionable car and then quickly see had they been back here before or not. We have caught folks that came thru during the day and then came back at night 3 months later, so we were able to get clean captures during the day of the car and even see the occupants.
The DB utility makes it a quick search. Could you imagine how long it would take to scrub video and see if that car had passed by before and if you even still have video that far back?
In addition to the quick video scrub I do every morning, I can quickly see how many vehicles the day/night before came thru. If all the vehicles are high repeats, makes it easy LOL. It is that 1st timer or less than X number at 2am that I look at in more detail.
Yeah I can see that use. No I wouldnt scrub through weeks let alone months to find a specific repeat.. I just dont see it being very helpful for a normal residential install. Outside of playing detective, because you have the time and can. I get that part.
Thank you for the insights. Not many people comparing the UniFi AI LPR with Axis or something outside the UniFi ecosystem. I’m trying to figure out if any 3x optical zoom (like, say, the G5 Pro) will work just as well if I add a good external IR Illuminator? Or do you suspect it’s also that the AI LPR is doing a much faster shutter speed (a setting I wish they would let us tweak)? I don’t care as much about the OCR or AI event as much as getting the best and clearest image capture.
The G5 Pro is 8MP on a sensor sized for 2MP so it would be poor.
External illumination for LPR only works if the beam is highly focused and is within the same plane of the camera. Folks have seen even being 2 feet apart results in an image for LPR not even looking like additional IR is being used. YMMV.
This camera is at full zoom about 12mm focal length, so if the vehicle is within 30ish feet it may work.
But there are much better options for less than that price.
Reactions: birdseed55
Would you care to elaborate?
500$ isn't cheap, but far from the 1‘000 or 1'500 other LPR cams are.
The downside of being forced to use their software for config is indeed a point. But you can run that on your own hardware, I heard. And you need some software anyway. If you're not already using another system that's not much of a down side.
I'm currently looking for something that works great an night, and preferably with a HomeAssistant integration. So I thought this one might be useful.
Yeah, in the $500 range these are great cameras that will actually read the plates and log them.
But many here run the Z12E that is $250ish.
The downside is this is set up for you to manually read the plates when you need to read them or use a 3rd party application to read them.
Some here use OpenALPR at like $10ish per month to do the actually reading of the plates and then a program someone wrote here to database log them.
Some here use Blue Iris as their VMS system and then use CodeProject ALPR to read and log plates and that is free.
Comes down to your system and which one you want to go with.
Don't forget the awesome ALPR DB system that @algertc has created. If people are recognizing plates but not yet logging them into a database, this is definitely something to consider.
I have a BlueIris setup running mainly for AI detection and Telegram Notifications.
Tried the ALPR setup once, quickyl, but failed due to bad camera angle. At night the camera was comepletely black anyway ^^
How hard is it to correctly setup such a Camera to get good results at day and night?
Planning to open the gate/barrier with that.
That sounds great.
Gonna look into that thanks.
All that AI Marketing Bullshit goes like "AI Surveillance detects cars and humans" wow Thanks. As if I couldn't see that if I look at it myself. Nice to have if you want to filter for certain actions. But that's it.
As Long as it doesn't detect a human doing something he shouldn't be doing, what's the use of that?
Also regarding ALPR... What if I want to know if a car is coming or going? How would I figure that out?
For direction of travel, in my case I have two zones (left and right) with motion triggered from A>B. Then I cloned the camera and changed it to B>A. So I end up with two virtual cameras with cars traveling one way detected on the first and in the other on the second.
Reactions: Haldi
It really isn't that hard. Just need to meet the following:
  • Camera capable of setting things like shutter speed and the camera honors it (unlike many consumer cams that will override any settings it feels is detrimental to a bright static image). Most here run a shutter speed of 1/1000 or 1/2000 and yes it will be an all black image at night, but the plates are reflective and you get the plate when it passes.
  • Camera with optical zoom capable of zooming in tight enough for the distance between the camera and the plate.
  • A decent angle to capture the plate.
Reactions: Valiant
