I've been trying to update the firmware on a Hikvision DS-7616NI-E2.
This version was purchased directly from a distributor in HK.
- so yes it's an "import"
- but it's an English Version
- and I can find no Chinese anywhere (so don't know if this is what people call "grey market"..)
Current Firmware: V3.3.4 build 150616
Latest Firmware: V3.4.92 build 170228
Downloaded from:
Hangzhou Hikvision Digital Technology Co. Ltd.
(Baseline Firmware_NVR (76/77NI-E)_ML_STD_V3.4.92_170228)
I've tried to update it from iVMS-4200 client software on Windows 10.
- goes "Upgrading Succeeded" and reboots
But then when I check SADP the version still says the old one (V3.3.4 build 150616)
Same results via Firefox v51 with Webcomponents active.
How I can upgrade?
- Is there somewhere else I should be downloading firmware updates from?
- Have I got the wrong digicap.dav file?
*Note: I'm trying to upgrade because I'm getting issues with recording on Motion detection.
- running 2 excellent WD Purple Western Digital 4TB SATA III 64Mb WD40PURX CCTV Hard Drives
Downloaded from:
How I can upgrade?
