Firmware issue with IPC-HDW5xR-ZE ??
Gadget -X
Getting comfortable
Apr 23, 2018
201
69
Mornin' Members: I was wondering if someone could shed light on what is up with my Dahua cameras.
I have 2.622.0000000.23.R, Build Date: 2018-03-30 on nine IPC-HDW5x31R-ZE cameras. I was wondering why some report Type "IPC" and some report "IPC-HDW5231R-ZE".(1st Photo) The ones which report "IPC" show the correct version in configtool. I checked and double checked they are all set exactly the same. (2nd photo).
I have not experienced any major issues with the setup except the date which flakes out every once in a while and the recording on SD needing to be reset every once in a while. I am hesitant to upgrade to the newest firmware after reading all the issues on 3 pages on the latest firmware thread.
Appreciate any help.
M
Reactions: Q™
I'd sure like to know the answer to this question also.
What version of the ConfigTool are you running?
I apologize. I am running ConfigTool 4.01.0 on my iMac Pro. Is there a later version?
M
Sometimes version nomenclature escapes me, so I'm uncertain if the attached version is a tad newer, or older. I am running Dahua ConfigTool 4.09 which is attached to this post and has been scanned with Eset NOD32 Antivirus for your safety...
Reactions: aristobrat
Sometimes version nomenclature escapes me, so I'm uncertain if the attached version is a tad newer, or older. I am running Dahua ConfigTool 4.09 which is attached to this post and has been scanned with Eset NOD32 Antivirus for your safety...View attachment 37836
Thanks, Q. I was able to spin up my Windows VM on my Mac and see that ConfigTool on Windows reported everything correctly whereas ConfigTool on macOS did not.
Windows (ConfigTool 4.09.0):
macOS (ConfigTool 4.01.0):
Side note, SmartPSS 2.00.0 on my Mac reports everything correctly (like the Windows version of ConfigTool).Untitled.png
If you click on a device, it will show you that device's firmware, but I don't see a way to get a list of all device's firmware versions on one screen.
wondering what the most current (working well)firmware for Dahua 5231 is right now...can someone let me know? Thanks
