Firmware for newer dahua cams as well as detailed specs available here
Hello, I'm looking for a firmware update but no luck so far...
the device is
IPC-HFW2831T-ZS
V2.800.0000000.7.R
2021-07-08
thanks
I've got several 5231rp-ze cameras. I haven't updated the firmware since purchase (I know, I know.. ) Anyone able to help let me know what the most recent version should be and where to get it?
Current:
2.460.0000.15.R, Build Date: 2017-09-07
Current:
What are you "I know, I know" meaning....
Many here do not update a perfectly working camera due to the likelihood the firmware bricks the camera or removes a feature you are using.
Unless you are experiencing a problem that the release notes so they fix, don't fix what ain't broke....
Does anyone know if the firmware on Download Firmwares for IPC-HDBW4231F-E2-M is the correct firmware for IPC-HDBW4231F-E2-M/M12? I'm not sure if the M12 on the end is actually a different model or not. I'm currently on "2.622.0000000.31.R, Build Date: 2018-08-13"
I also have a SD59230U-HNI that I purchased from EMPIRETECANDY, running firmware "2.623.1090003.0.R, Build Date: 2019-01-2". I can't find anything for this model on his firmware page, but it would be nice to move to a newer firmware that doesn't require Internet Explorer. I found newer versions here DahuaWiki but I don't think these can be used since the camera is not Dahua branded?
Bonjour, j'ai moi meme une sd59225u-hni achetée aussi chez EMPIRECANDY et j'utilise le firmware suivant :
et le tout fonctionne très bien.
Anyone have latest Firmware for Dahua DH-SD59230U-HNI?
Thanks
Yea, that was the first thing I saw...
Except, the url doesnt seem to be working for me.....lol
Ok, je vois où est le problème. Toutes mes excuses, mon français est un peu rouillé. J'ai d'abord dû me rendre au champ de bananes avec ma tête de chien. J'ai ensuite utilisé mon téléphone pour accéder à l'URL afin de télécharger le fichier. Je soupçonnais qu'un pare-feu bloquait l'accès via mon ordinateur portable. Veuillez pardonner mon erreur cérébrale et merci pour votre patience. Cordialement, Vive la France.
Reactions: cuistots
Hello. Can you tell me what firmware I can install instead of the original one to make the English language appear in the settings? I bought the camera in China, the DH-IPC-HDW4843T-A has firmware version v2.820.0000000.32.R
provide your HWID. if doesnt known what is HWID and at least UART, forget about idea to touch firmware.
Hello, my first post here..
I got my nands on two old Dahua cameras, and they appear to be running on 2019 firmware.
Both cameras report as follows:
Device Type IPC-HDBW2231R-ZS
System Version V2.800.0000000.3.R, Build Date: 2019-08-16
WEB Version V3.2.1.775447
ONVIF Version 18.06(V2.4.5.698080)
S/N 5H082DAPAG812AC
Algorithm Version 1.0.0
Security Baseline Version V2.0
S/N5 H082DAPAGD89F6
I am aware that there is a newer firmware from 2021 available for this camera model, but the download links have died.
I am requesting help from the community for the firmware update to the latest official version.
The cameras are working Ok and they are located at rather remote location but it would be nice to have the latest firmware running at them..
Also, if the update requires some middle version to update first, please provide link to that as well.
I am looking for PAL / English firmware version.
Thank you!
