Firmware for IP Camera (DS-2CD3346WD-I)
bosseli
Mar 27, 2025
4
Philippines
Hello, I'd like to modify the firmware on my Hikvision IP Camera. The default firmware is in Chinese. I need an English firmware version. Thank you!
Software version: V5.5.80build 180911
"an English firmware version" won't change the language the camera uses and will likely not install with a 'language mismatch' error.
The camera region / language is defined by the device-specific protected 'bootpara' data that's written into the camera itself during manufacture. This holds model code, capabaility, region, language. OEM code etc.
The serial number in your screenshot includes CCCH which means it's a Chinese camera.
Noted, thanks for the info
