what software are you trying to get the camera to work with?Is there a logical way to determine the video path of a IP camera that does not setup automatically?
I have a i3 International camera, model Ax52R that is H.264 compatible but I cant get it to configure properly.
Any ideas?
The camera is onvif compliant...use the onvif device manager and it will give you the rtsp stream.Blue Iris Ver 4
how do you know its reporting it incorrectly?Thanks
onvif reports it incorrectly. I also followed your links and looked at the ispy site but there was no info for this camera.
You are likely not entering it properly in the path...please post an image of your video configuration settings in blue iris. Double check the ports as well.well that's a good question. I guess I just assumed that being I get "No Signal" as a response, it was incorrect.
I know the creds are correct and address what am I missing?
