Instead of a network, I currently have a not-work...
I'm trying to set up an IP cam network and part of that network is to be extended to a detached building that will be connected via optical fiber.
I have the following hardware:
2 MikroTik RB260GS switches (firmware v 2.13), which includes an SFP port. All switch configurations are default settings.
SFP modules: HiFiber 1.25G Single Mode SFP LC Modules, 1000Base-LX/LH Fiber Transceiver
Cable: FiberCablesDirect OS2 LC LC Fiber Patch Cable | In/Outdoor Duplex 9/125 Singlemode
fibercablesdirect.com
In my test setup, I have my PC connected to the first switch (192.168.50.104) then to the second switch (192.168.50.102).
When the switches are connected via Ethernet and with the fiber disconnected, I can connect to each switch.
They both report the SFP module is part number "GLC-LH-SMD" and the type is "1310nm multi-mode fiber".
When I connect the switches with fiber and disconnect the Ethernet, 192.168.50.102 either does not respond to pings (timeout) or once in a while a packet will get through.
Is the SFP module is incompatible (since it should be single mode but reports as multi-mode) or is there something else I should be looking for?
OS2 LC LC Indoor/Outdoor Duplex SM Fiber Patch Cable 9/125 Singlemode
LC LC Single Mode Fiber Patch Cable | In/Outdoor Duplex OS2 9/125, tightly buffered, black, 1/10/40/100Gb jumper, LC terminated, w/18in. 2.0mm furcation tubing.
