Fiber instead of PoE, what about power?
luk8899
Mar 8, 2024
50
28
Poland
I'm considering swapping my PoE setup for fiber on my cameras for reasons of better lightning survivability (lightning just blowing up a camera nearby rather than half of the system as it happened once for me). My cameras are mounted on 6m tall steel poles which are 1.5m in the ground. So 4.5m.above ground and two cameras on each pole.
I wonder what about power. Someone may say "What about it? Just run AC 240V(this being our voltage) same as for anything else and use normal surge protection" However that is a copper cable that will be exposed to the same risk PoE cables were, also same issues with grounding and so on. I can put in surge protectors (just like I can on PoE), but if these surge protectors get overwhelmed I can potentially destroy a lot more expensive equipment connected to AC power than a couple of cameras and switches...
Then there is the cost of running AC power properly that seems much higher than just running PoE for both.
Finally there is the fact I currently just need a small sealed box to terminate the copper in and have a tiny poe splitter for cameras that do not support PoE out of the box. This box would have to become much bigger to fit a media converter, ac fuses and AC surge protection.
I'd love to read about your experiences with this if you live in a high lightning area of not? Is there much benefit to fiber outdoors on distances where copper works fine?
Are there some unexpected advantages/disadvantages of fiber I'm not thinking of? What about the efficiency of power? My system of 11 cameras and various switching equipment consumes 150W most of the time. While electricity is free in the summer for me (thanks to PV/batteries) in the winter I pay quite a bit and the Cctv system is probably responsible for 20% of my entire bill because it's running 24/7. I'd think perhaps PoE switches are more effecient at AC->low voltage DC conversion than "wall warts" sold with cameras, but maybe it's the opposite?
Edit: Also PoE is handy for occasionally (or regularly) restarting cameras which freeze/crash so you can't manage them. If this was using AC power.id have to use some IP relays. Probably out in the box with the media converter.
Only places I’ve seen that were either large footprint or hardened DoD facilities. Unless you’re running and fusion splicing it yourself it’s not feasible vs the cost of replacing a couple cams. When you say “surge protectors”, are you referring to the bs power strips that everyone calls “surge protectors?”
I’d look into real protection/power conditioner and/or maybe a star type network with hardened poe switches (DiN) in between cameras and network equipment.
I don't mean to come off as rude, but what are you talking about, and how many hardened DoD facilities have you been to? This comment comes across like its from someone who has never worked with fiber before in their life.
Running fiber is trivial and often times easier than copper as there are less length limitations, no interference limitations and no electrical implications. You can terminate fiber easily, or you can just buy pre-made patch cables with whatever connector you want and run that.
Why you think you need a fusion splicer is beyond me
Ever heard the expression “everything before ‘but’ is meaningless bs?”
I’ve worked on several with inner and outer peremiters with ptz, thermal and buffer zones. This being the most recent.
And I’ve never heard of a “professional” using premade Ethernet or fiber runs let alone mechanical splices.
Why are we splicing fiber at all?
Termination is not splicing
If you’ve never heard of professionals using pre-terminated fiber then you may not know many professionals
Also, why do we care what “professionals” are doing? OP is installing a few cameras, not a mission critical undersea cable
Reactions: Virga and looney2ns
This post was not meant as a discussion of fiber feasibility, but on the ways people run power alongside it when they want immunity from EMP (such as caused by nearby lightning strike) and voltage gradients in the soil caused by the same.
I'd love to hear what worked, what didn't and so on. I'm fairly well informed on the subject of single building protection, but this is a special circumstance.
No, I'm referring to surge protectors installed in electrical cabinets like this:
This happens to be type 1+2 (or B+C) which is the minimum required in any residential building with a lightning rod/system.
The above is real, but for anyone reading this please be mindful it's capability depends on the single point grounding quality you have.
Single point grounding is impossible if you have multiple buildings or remote sensors like cameras.
The classic advice is to ground each site so each site has its own single point ground and surge protect every cable on both ends that connects the two sites. Also if you're using any other copper wiring (PoE etc) it should enter the buildings at the same place as the electric utility and grounding and be surge protected there. This is a big obstacle for many people me included.
Even if I had this same place entry and space to locate my switching gear there the cost to surge protect Ethernet to comparable level is much higher due to topology (and remember surge protectors are consumables, have you ever seen an Ethernet surge protector with an "end of life" indicator? I haven't).
That is what I have now (actually 3 star network with links between) and I'm replacing it with fiber (not everything , but the longest runs).
You can buy terminated fiber in many different lengths off the shelf. You can custom order runs to exact length if you wish. If you have a conduit large enough to pull LC plugs there is no need for a fusion splicer.
You can also polish your own connectors if you're doing DIY.
Indeed, this is my property and I consider it a DIY project.
If anyone is interested why I'm interested in fiber now here it is.
I've recently run my own fiber (12 strand single mode g657.a2 in UV resistant TPU) between my house and another building on my property to provide 10G connectivity( I had an old copper cable installed that could only manage 2.5G).
Regarding costs 10G SM 10km SFPs were $11 each (the run is only few dozen meters, but multimode is actually more expensive now here, so I chose single mode).
I've terminated it with pigtails and mechanical splices for now while I'm waiting for my fusion splicer to arrive from China. I could've done polished epoxy connectors instead without the large expense and that was the original plan until I realised I'll have a lot more places on my property to run fiber to, and I found a splicer for 360 EUR. So I decided mechanical splices are fine for few weeks.
The only reason why I didn't choose preterminated is because I have few very tight bends and I could not find preterminated g657.a2 fiber (which has the amazing bend radius of 7.5mm). Also to pull it through a 1in conduit into the other building and the fact I can get 12 strands for half of the cost of 2.
I have a relatively large property with many small buildings and cameras on steel poles. Lightning is a real issue. I've already lost one switch and a bunch of PoE adapters once. I consider myself lucky.
IT Infrastructure Engineer
it sounds like you are picking what you are sacrificing, keep in mind depending on what hits you, you're going to blow up stuff anyway. if fiber's a feasible option you could run a PoE injector that's cheap and easy to replace to supply power and assume whatever's supplying the PoE injector will have enough protection itself & keep a few spares of whatever that is (but not have the PoE injector connected to your network.. just supplying power)
No BS, what do you guys do for a living?
IT as well (Devops engineer). But my dad is an electrician (retired now). I've spent many summers as a young kid and teenager making extra cash helping him on various jobs. Most were wiring new builds, including installing the main utility connections, grounding, lighting rods (although I never worked on the bit on the roof) and so on. So I'm not afraid to do my own electric (and small sm0
()cale building) work.
This is something to ponder about. Both options have their pros and cons (AC vs PoE only for power).
On the surge protection side this is basically using these PoE adapters/injectors as sacrificial surge protectors. The cheapest, but still reputable surge protection that covers types 1+2+3 is 30 EUR. The cheapest PoE injector is 3 EUR.
It would be an interesting experiment to have at least one or two cameras on AC to compare in terms of surges.
But you and loony have never climbed a pole. Big red fish and some of as has, for decades.
LOL, my last pole was about 1980 or so. They had just started running fiber, mostly underground. Us pole climbers were still splicing copper. Hell even that was a specialty. I was a dumb 'ol lineman, splicers made the big bucks :rofl:
Whats that got to do with any of this? Do you think Fiber is exclusive to poles?
I think what you need to add is a PoE Surge Protector which is used for your camera system,it can be cheaper and easier than change the whole system to Fiber.
Surge protector is only as good as the ground it is connected to. To properly surge protect PoE one needs to route them where the single point ground is connected - usually the main electric utility cabinet. Unfortunately I can't do that. I may have mentioned it in this thread.
If someone can do that surge protecting PoE is certainly an option.
But it is also important to mention there are many crappy surge protectors for PoE on the market. An effective surge protector has to provide type 1+2 protection on all the pairs differentially and from each pair to ground. It has to do that without adding too much capacitance to maintain whatever Cat rating of the connection. It is not cheap. Starting at $20 per connection for the cheaper ones and going up. I think I found one I could trust for $40 or so and that's a consumable, per switch port. Still if one can route all their cables through one service entrance that is not a bad option considering other advantages of PoE (one cable, no extra devices at camera end).
BTW, I have the fiber fusion welder now. I've thrown out the mechanical splices on the fiber between the house and a separate building. Making good connections is not difficult at all. The machine does it's thing automatically.
The only difficulty is adding cables to existing underground pipes. I'm not sure how they do it in the industry and avoid things getting entangled. I have two cat6 ground rated gel filled cables in a 45m long 50mm pipe. I don't know how by trying to add extra electric wire to this (a pretty thick half inch cable) it always gets stuck. I was planning to add this electric cable. Then fiber two weeks later. But I think I have to pull these two cat 6 cables out and pull everything together. While I can do it in this case I have other ducts that already have electric cabling and cat6 I was planning to add fiber to it and most certainly I'll not be pulling everything out to install fiber.
So, I wonder how do they install miles of underground channels. Put cables in for years and just add one or two extra cables from time to time without any entanglement. If anyone knows please share.
Reactions: bp2008
Well,well.. Turns out that cable duct that I had so much trouble with is collapsed or squeezed between something. I thought it is the bends that were causing the problem or the cables are getting entangled. Nope. Digging down to the straight section pushing and pulling through it required lots of force. The strongest piece of string that would still be slick enough I found was 3x3mm square profile weed whacker string. It took the strongest pull I could muster and eventually I did manage to pull both the fiber and an extra thick power cable I had to run through the same duct (not for the cameras).
I then went to a different duct nd discovered that despite being longer it is extremely easy to both push the rod as well as pull the cable.
So no special solutions required . Just not having collapsed ducts is enough.
Reactions: TonyR
Is the cable tied to that fence running to that PTZ or ????
Reactions: TonyR
Electrical engineer. I use surge protectors. One is grounded to my generator. Another I bought a 8 foot copper rod and hammered it as deep into the ground as I could. Haven't lost anything since I have done this to lightning.
I do a lot of work with fiber cut I didn't realize it was easy to terminate now. It used to be a huge deal, and even where I work it is but our requirements may be nuts.
