Feedback on these Axis Cameras?
Nortron
May 19, 2022
3
Ontario, Canada
Hello
Does anyone have any feedback on these Axis camera models? I'm new to this... Looking for good quality day and night vision. Will be using them with blue iris I think...
M3025-VE
M3004-V
Q6035-E
0482-501-01
These are old discontinued models
Yes they are. But will the produce good quality video? I might be able to get them cheap but don't want to bother if they just produce fuzzy video... I'm to new to this to really know the fine details of the specs etc. So not sure what's good and not good yet ..
Thanks.
As stated above, these are old models. Info from Axis below:
M3025-VE: 2MP on a 1/2.7 sensor. Min illumination is quite high compared to current Dahua cams. Has a wide angle 3.6mm lens so not good for face ID unless the cam is close. No mention of IR.
M3004-V: 1MP on a 1/4 sensor, which is quite small. Min illumination is very high, even compared to the M3025-VE. Has a very wide angle 2.8mm lens. Does not seem to have IR.
Q6035-E: Axis has no info on the video resolution, but it is on a 1/2.8 sensor. Min illumination is high. This is a PTZ cam with 4.7-94 mm lens.
0482-501-01: this model number is not found on Axis website.
Personally, I would rather pay $200-$250 for some very good Dahua prosumer cams, cams that I know will give me great video, than $10 for any of those cams. But that is just me.
Perfect Information, Thanks for the assistance!
