Feedback on DORI-based Camera Selection (Front Door & Garage) - Did I Overkill or Misunderstand?
phdelodder
Oct 15, 2025
12
9
Belgium
Hello everyone,
I've been going down the rabbit hole and trying to apply the DORI methodology for my camera selections, with a specific focus on achieving Identification at my critical choke points.
I've read and tried to understand the core concepts in these two threads:
Based on my desired Identification distance and FOV, here are my proposed camera selections. I'd appreciate feedback on whether these are overkill, or if I have completely misunderstood the application of DORI/focal length concepts, particularly for the longer 15m range.
I have attached an image showing the general layout for reference.
Use Case 1: Front Door/Entry Point
  • Goal: Identification of a person (face/features).
  • Critical Distance: A few meters (let's say 3-5m).
  • Required FOV: Approximately 60° (to cover the landing/walkway).
  • Selected Cameras (4MP):
    • HIKVISION DS-2CD2346G2H-I(U)
    • Dahua IPC-HDW3441EM-S-S2
Use Case 2: Garage/Driveway Coverage
  • Goal: Identification of a person (face/features) entering the area.
  • Critical Distance: Approximately 15 meters.
  • Required FOV: 90° (to cover the full width of the driveway).
  • Selected Cameras:
    • 4MP (Varifocal for dialing in focal length):
      • HIKVISION DS-2CD2H46G2-IZS(2.8-12mm) — My reasoning here is to use the varifocal to dial in the focal length (likely 6mm-8mm) necessary to hit the required Identification PPI at 15m, as DORI calculators suggest.
      • Dahua IPC-HDW3449T-ZS-IL
    • 8MP (Vari focal, High-Res):
      • Dahua IPC-HDW3849T-ZS-IL
      • Hikvision DS-2CD2H86G2-IZS
My main question is: For the 15m / 90° requirement, are the 4MP or 8MP cameras listed appropriate, or have I over-spec'd them? Given the distance and wide FOV, I know I need higher pixel density/a longer focal length, but am I focusing too much on the MP count instead of the lens?
Any guidance on my selections would be greatly appreciated!
  • 60091596_new_floorplan_gelijkvloers_first_design_20251008_b40d2c-plaatsing.jpg
