Fastest trigger notification?
105437
BIT Beta Team
Jun 8, 2015
2,161
1,053
I’m curious if anyone has tested to see what the fastest trigger notification is. Is it a push notification to the BI app, email notification sent to your Gmail account or Pushover?
I’m going to try and do a little testing tonight, but I wanted to hear any feedback from others who may have already gone down this road.
Thanks
I have done it and they are generally close. At least close enough to not make a difference.
When I tested it some days BI app was faster and some days Pushover was faster.
Reactions: 105437
How many seconds were you experiencing between the start of the trigger and receiving the notification?
Mine would range from 1 second to 4 seconds, but they would literally ding just about on top of one another. Speed will be based on your computer, what else is going on motion wise, and internet speed. I have a 4th Gen so mine is slower than folks with a newer that would get sub second times.
SMS was the fastest but that is so inconsistent now with all the mobile providers tightening their spam.
Reactions: 105437
As another data point, I use the send an email to phone as text <phone_number>@<gateway> method: it is something like [email protected] for T-Mobile, for example.
Slow though, usually takes 10-15 seconds.
Reactions: 105437
Have any of you noticed that attaching the alert image to an email alert under the Trigger Tab/Immediate Actions, attaches a random alert image from another camera? Doing this from the Alert Tab works as expected.
I have not noticed that it was from another camera, but yes, I have noticed that the image is from one of the Alerts and often not the expected
image. I've always assumed that was doing something wrong.
Reactions: 105437
