Looking for recommendations for a fan less switch, probably as many ports as I can get for being fanless, gigabit would be nice but since it will run mostly IP cams not that big a deal.
Amazon.com: Zyxel 8-Port Gigabit Ethernet Smart Managed PoE Switch with 70 Watt Budget - Fanless Design [GS1900-8HP]: Computers & AccessoriesLooking for recommendations for a fan less switch, probably as many ports as I can get for being fanless, gigabit would be nice but since it will run mostly IP cams not that big a deal.
I have two dlink 24 port if you are interested.
you just don't need them anymore?
Well not currently in use. I had bought a netgear switch with vlan capability to try out. So these two are just sitting around. I'm missing two screws on one of the rack mount brackets.
