T thiago.tss n3wb Dec 27, 2021 1 0 Salvador Dec 27, 2021 #1 I'm trying to reset the password of a camera that is far away from me. Every time I try to get the key it keeps giving this error. What could it be ? this only happens on cameras that are more than 100m from my location
trempa92 Getting comfortable Mar 26, 2020 1,179 379 Croatia,Zagreb Dec 31, 2021 #2 I had exact same problem today, make sure you aren't behind smart switches with rulesets, also if you are using wifi , connect with cable.
iTuneDVR Pulling my weight Aug 23, 2014 881 163 Россия Dec 31, 2021 #3 Generate XML & do not reset your decive. Remember Start time!!!
