bickford Getting comfortable Mar 12, 2016 468 432 Dec 26, 2018 #21 Q™ said: I own this camera and it is E X C E L L E N T. Click to expand... No problem with focus ? ir power is good enough ? thanks BIck
Q™ IPCT Contributor Feb 16, 2015 4,939 3,988 Megatroplis, USA Dec 26, 2018 #22 bickford said: No problem with focus ? ir power is good enough ? Click to expand...
bickford Getting comfortable Mar 12, 2016 468 432 Dec 27, 2018 #23 please answer my question before cutting my head =) BICK
BoomerangThree n3wb Dec 25, 2018 12 1 Suwanee, GA Dec 27, 2018 #24 " data-source="post: 322311" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> Q said: I own this camera and it is E X C E L L E N T. Click to expand... At what angle will it NOT ID tags consistently? Sent from my iPad using Tapatalk
bigredfish IPCT+ Member Sep 5, 2016 33,034 80,145 The Swamp Dec 27, 2018 #25 Generally speaking, you want to keep the angle of attack at less than 30 degrees for LPR regardless of the camera. Straight on is ideal Reactions: BoomerangThree
