Hi all,
I am slowly learning and getting my NVR and cameras set up. My current step is trying to get notifications working. I can get things like Motion Detection, Cam Masking and Scene Changing working via the DMSS app, but have not had any luck with smart features like face detection, human/vehicle detections, tripwires etc.
I realise some of these may only be available whether I select Face Detection or IVS in the Smart Plan section, or maybe they are not available on the particular hardware I have (it was all already installed in the house I bought).
So my questions are:
Cameras (connected to the NVR via PoE: DH-IPC-HDW4631EMP-0280B
Thanks in advance!
- What detection/notification features are available with Face Detection vs IVS selected?
- Are my cameras/NVR combination even compatible to use these features (models below)? I looked online and it appeared the cameras have IVS, but not sure about the NVR. It looks like it has SMD, but when I go there in the NVR it says "The config is not supported".
Thanks in advance!
