Not sure if this is a networking/ASUS quesion or Hikvision question. Its really both probably.
I have a number of problems with the EZVIZ app on my Samsung tablet A.
I do not have an account with Hikvision, I just use it by connecting to the network and searching for the Hikvision camera. This works when connected to my router.
In my setup i have two routers, one is the ISP the other an ASUS RT-AC66B1 with OpenVPN setup This works fine. I have port forward on for the VPN port in my first router which is my ISP's. Again this works fine.
When I login via vpn this logs me into my second router (The ASUS), However when I run the EZVIZ app on my Tablet. It does not find the Hikvision camera. (When logged in via VPN)
However, the other Hikvision app the IVMS-4500 does work. So does my Geovision app for my Geovision Camera. The Hikvision camera appears to use port 8001 to stream video. This port has been enabled on the camera, To prove this the IVMS-4500 works fine, using port 8001.
When I turn off the VPN and login to wifi locally to the second router. The EZVIZ works fine.
So the problem, to be clear is that EZVIZ does not work when using VPN, but other camera apps do work. Including other Hikvision app.
Sense that the problem is in the way that the EZVIZ searches for the camera. But I really dont know.
Can anyone give any answers to this mystery?
Regrdss
Regrdss
