Hi All,
New to all this surveillance stuff and I have some questions about onvif features and how this Ezviz DB1C works with Blue Iris and/or Zoneminder.
I've done some research over the past couple weeks, and confusion on onvif is growing. I now know it's for cross vendor support, allowing multiple brands to integrate, but what else does it do?
My main requirements:
Video surveillance with motion detection triggering the cam to record to my server, along with sending an alert to my phone.
I got my feet wet by installing ZoneMinder and connecting a basic web cam to it. I found that I could set up multiple monitoring zones and a motion trigger to capture short videos to the hard drive. Since it's a crappy low def cam, I was surprised that it worked, and at this point I thought only onvif cams could do motion detection, but it seems to work through the software.
How does the onboard Image Change/Human Detection work with Blue Iris or zoneminder? I'm guessing the Blue Iris/Zoneminder have their own algorithms for motion detecting and only use the raw feed from the rtsp link? So having the AI on the camera would be redundant?
I've read the review post by silencery here: https://ipcamtalk.com/threads/review-ezviz-db1c.52789/ which was very informative, but I have a question about this:
What do I really need onvif for?
Sorry for all the newb questions! Appreciate any advice.
Cheers
I'm really not sure what you mean about triggering the recordings? Do you mean that the db1c would send a trigger to Blue Iris to start recording? But this leads to another question, why does my cheap webcam work with motion detection recording? It's certainly not onvif capable! I'm really confused.If EZVIZ ever did bring ONVIF event capability to the DB1C, AI detection would be useful for NVR users to trigger recordings
Cheers
