hi
i have a ezviz db1 with a MS intercom (MS MC170).
I purchased a transformer that does 8, 16 and 24v, i hooked it up to the 24v 20va option, a 24v relay, and connected everything up, when i measure the voltage at the door bell, it reads 24-27, however the relay LED is constantly lit, and the video doorbell keeps chiming non-stop as if someone was repeatedly pressing on the video doorbell
i followed the connection instructions i found off reddit to connect everything, but i am not sure what i am doing wrong
is it possible that the transformer is not strong enough? (only 20va, not 40va)?
relay: URBEST HH52P AC 24V Coil DPDT 8 Pins Electromagnetic Power Relay w DYF08A Base : Amazon.ca: Automotive
transformer:
if anyone can shed some light, i would be grateful (maybe the instructions arent correct?)
thank you
transformer:
https://www.lowes.ca/product/doorbell-parts-accessories/utilitech-wired-door-chime-transformer-63548
thank you
