Hello,
I've just bought an ezviz CS-CV248 camera which was labeled by the seller as a device registered to a different user. I'm not a fun of cloud offered features especially in a surveilance applications so I planned to use it locally. Unfortunatelly the device bootloops. I started from attaching a console and finally I got an output from the boot process:
Please help me with spotting the source of an error causing the davinci to bootloop
I'm not familiar with a davinci software suite but I managed to break the loading process during the reset of the wifi card in initrun.sh and got a console with root privileges. After this I configured the eth0 and managed to download the ipc_db to the PC. The database seems to be OK (can browse under the sqlite3 viewer). I also dumped the whole flash image so I can attach the content of the /dev partition if needed
Regards
Marek
Code:
System startup
svn_ver:39700 (Aug 29 2018 - 15:17:58)
DRAM: 64 MiB
Check Flash Memory Controller v100 ... Found
SPI Nor(cs 0) ID: 0xc8 0x40 0x18
Block:64KB Chip:16MB Name:"GD25Q128"
SPI Nor total size: 16MB
MMC:
EMMC/MMC/SD controller initialization.
Card did not respond to voltage select!
No EMMC/MMC/SD device found !
In: serial
Out: serial
Err: serial
*No SD card found!
No mmc storage device found!
load_update_file fail
Hit Ctrl+u to stop autoboot: 2 1 0
load kernel to 0x80007fc0 ...
check backup upgrade flag
Done!
## Booting kernel from Legacy Image at 80007fc0 ...
Image Name: Linux-3.4.35
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2044440 Bytes = 1.9 MiB
Load Address: 80008000
Entry Point: 80008000
XIP Kernel Image ... OK
OK
Starting kernel ...
init started: BusyBox v1.22.1 (2018-09-05 11:32:22 CST)
8188eu.ko ASC16 ASC32.bin HZK16 bcm43143.ko bcmdl blogo.bin certs.tar.gz da_info davinci default.script dhcpd.conf execSystemCmd flash_eraseall fw_bcmdhd_r79.bin.trx gpio_test hi_cipher.ko hostapd initrun.sh ipchelper libbonjour.so libezDevSDK_Common_Module.so libezDevSDK_boot.so libmicrokernel.so libnl-genl.so.2.0.0 libnl.so.2.0.0 libr2_isp.so libsqlite3.so libusb-0.1.so libusb-1.0.so libwolfssl.so load_module.sh mav_cal.conf mfgutil mlan.ko mlogo.bin nvram_wubb-738gn.nvm r2_modules.tgz slogo.bin step_motor.ko t1 udhcpd usb8801.ko usb8801_uapsta.bin voice voice.tar.gz wpa_cli wpa_supplicant
mmz_start: 0x82400000, mmz_size: 28M
0x200f0040: 0x00000000 --> 0x00000002
0x200f0044: 0x00000000 --> 0x00000002
0x200f007c: 0x00000000 --> 0x00000001
0x200f0080: 0x00000000 --> 0x00000001
0x200f0084: 0x00000000 --> 0x00000001
0x200f0088: 0x00000000 --> 0x00000001
0x200f008c: 0x00000000 --> 0x00000002
0x200f0090: 0x00000000 --> 0x00000002
0x200f0094: 0x00000000 --> 0x00000001
0x2003002c: 0x000C4003 --> 0x000C4001
==== Your input Sensor type is ov9750 ====
out gpio_pin=38 val=1
out gpio_pin=38 val=0
ln: help: File exists
/ # LIBSYS Utils : ipchelper
autoApp = 2
LIBSYS Utils : Auto to start program
LIBSYS Utils :
== DEVICE INFO ==
LIBSYS Utils : device : flash size = 16 MB, ram size = 64 MB
LIBSYS Utils : kernel : version 3.4.35, build number = 20120425
dbg <sysInit>:bootParms.videoinType=45
LIBSYS Utils : make_serial_no: CS-CV248-A0-<OMMITED>
fm2018_init type=0.
LIBSYS ERROR: FILE->Src/Devices/EchoCancellation/fm2018.c, LINE->291:Open i2c-2 error!
[10 01:05:46][DEVLOG][ERROR]zone:8 timzezone[1:0], Dst enable:1, DSTBias:60, tz_index:138, start[3-5-0-2],end[10-5-0-3]
[10 01:05:46][DEVLOG][ERROR]timezone[1:0]
powerLineFrequencyMode = 0
db version old: 1136, cur: 1136
[10 01:05:47][OTHER][ERROR]Direct reading of the database
[device status]idx: 1, enable: 1
[device status]idx: 2, enable: 0
[device status]idx: 7, enable: 0
[device status]idx: 9, enable: 0
[device status]idx: 10, enable: 1
[device status]idx: 21, enable: 0
[device status]idx: 22, enable: 0
[device status]idx: 25, enable: 0
[device status]idx: 29, enable: 0
[device status]idx: 2000, enable: 0
[device status]idx: 2201, enable: 2
[10 01:05:47][OTHER][ERROR]openPrivacy_steps:0
[10 01:05:47][OTHER][ERROR]isPanReversed:0
[10 01:05:47][OTHER][ERROR]isTiltReversed:0
[10 01:05:47][OTHER][ERROR]PresetDefined:0
[10 01:05:47][OTHER][ERROR]pan_pos:0
[10 01:05:47][OTHER][ERROR]tilt_pos:5
create bcm config file zone = 8
adjust time: adjusttimebyrtc stime ret=0, adjustTime=1294621547, currtime:1294621547
[10 01:05:47][HW_IF][ERROR]insmod /dav/step_motor.ko succ
[10 01:05:48][SDKCMD][ERROR]start [eth0] dhcp task
[10 01:05:48][DSP][ERROR]g_pdsp->viResolution = 0x101b
[10 01:05:48][DSP][ERROR]g_pdsp->VideoInitParam.max_viW = 1920
[10 01:05:48][DSP][ERROR]g_pdsp->VideoInitParam.max_viH = 1080
[10 01:05:48][DSP][ERROR]g_pdsp->VideoInitParam.original_viW = 1920
[10 01:05:48][DSP][ERROR]g_pdsp->VideoInitParam.original_viH = 1080
[10 01:05:48][DSP][ERROR]g_pdsp->VideoInitParam.image_viW = 1920
[10 01:05:48][DSP][ERROR]g_pdsp->VideoInitParam.image_viH = 1080
[10 01:05:48][DSP][ERROR]hwif_dsp_init start_dsp before
**************ezdsp SVN*************
********SVN VERSION IS 40487********
********Dsp Dev Ability*********
YsDevType: 5
u32AuADCVal: 19
u32AuDACVal: 14
u32IvsStartThr: 70
IvsSensity: 80
u32QrWidth: 512
u32QrHeight: 288
<lib> dspTaskCreat ok!
=============SAMPLE_COMM_VI_SetMipiAttr ViType: 64
<ISP> isp start
<ISP> img size 0 x 0
<ISP>is outdoor 0
<ISP>isp ae cfg reg : 0
linear mode
=====sensor mipi 1080P15fps linear mode init success!=====
Regards
Marek
